Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: How to wire a GY6 engine into a Honda Ruckus
PostPosted: Thu Sep 08, 2011 8:38 pm
the links aren't working! :pissed:
can you pm me a link? :lol:
viewtopic.php?f=93&t=61225
^ Lady Trouble ^
http://www.scgcreations.com/
PostPosted: Tue Sep 13, 2011 4:04 pm
Im in the same boat need the diagram if somebody can send it over to me.
PostPosted: Wed Sep 14, 2011 11:11 pm
Sucks! Links are down! I need that pdf! :D
PostPosted: Wed Sep 28, 2011 6:04 am
Found a link to another site that had this diagram posted. Here you guys go:
http://g3integra.com/ruckus/40/ruckus-g ... g-diagram/
PostPosted: Wed Sep 28, 2011 6:05 am
Here is a picture of it too:
PostPosted: Fri Nov 18, 2011 9:14 pm
if i ever do a second swap im using this. I love the ease of my ATR harness, but doing it myself will be fun....i think?
My sad excuse for a build thread
PostPosted: Mon Nov 21, 2011 11:58 am
I just got mine all wired up using this diagram and it worked perfectly on the first try. I have yet to wire the lighting but im pumped, thanks for this information
my swapped rwd honda:
viewtopic.php?f=92&t=62006
PostPosted: Mon Dec 05, 2011 8:27 am
finally got around to doing my lighting. blinkers wont work. I realize Im running a metropolitan turn signal flasher and it only has two wires (black and grey) . any advice on this?
thanks
 Post subject: gy6 harness for swap?
PostPosted: Mon Jan 02, 2012 9:13 pm
So after stripping down my donor scooter I don't see why more people don't fully remove the stock get harness and adapt the gy6 harness to the ruck. Is it because most of you are buying all the parts seperate? Maybe I missed something but if I not this will be the way I attempt the install.
Thanks in advance for any I site!
Build page----> viewtopic.php?f=93&t=64479
 Post subject: Re: gy6 harness for swap?
PostPosted: Mon Jan 02, 2012 9:15 pm
been done a million times, obviously you didnt try searching about this at all
MY OLD 40K MILE RUCK
MY JANKY NEW BUILD
PostPosted: Tue Jan 03, 2012 11:07 pm
I like how you say search, which I have by the way, I was really looking to bring up a current discussion on it. I guess pulling my post off the main page and adding it to a broken link sticky makes sense... :pissed:
PostPosted: Mon Jan 09, 2012 12:25 am
That's a good question man. I often wonder if it's just because if the particular differences in the wiring run or something more complicated. I just started my ruck after wiring it up using this harness schematic. I am sure it would have been quicker to simply completely swap the donor harness.
- something clever goes here
viewtopic.php?f=92&t=45383
PostPosted: Mon Jan 09, 2012 12:29 am
quicker only if you wanted everything in the wrong place lol
MY JANKY NEW BUILD
PostPosted: Mon Jan 09, 2012 9:48 am
So then it does come down to wiring run. Probably a few other areas of issue as well.
PostPosted: Sat Jan 28, 2012 11:02 pm
This Thread is USELESS without working links. :headbashing:
1986 Elite 80 YT
1986 Elite 80 Slammy Hagar
2009 Kymco Agility 125
2013 Ruckus GET 50
