Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: @@READ ME@@ GY6 TECHNICAL SERVICE BULLETIN
PostPosted: Thu Sep 23, 2010 4:37 pm
Man, THANKS for letting me know that! It drove me crazy thinking that little "c" clip was holding that sucker in.....
I thought the raised area floated in the bearing area and the c clip held it in....... So it's not really possible for that sucker to come out that way....
Sweet!
Now to just reinforce the case.
So what does the "relief" cut help? Instead of a 90 degree corner, it is a rounded cut so the crack cannot start? I might do this as well.
Here's what we did tonight:
http://picasaweb.google.com/jp6940/Toys?feat=directlink
(last few pics)
We spent a few hours reinforcing/thinking/cutting metal. I think it will work pretty well.
Keep in mind it's R O U G H. I need a lot of sanding/grinding/clean-up but you should get the idea of where we were heading....
"BlueBallz,Darkness,Scrappy,MetRuckus" projects!!
viewtopic.php?f=93&t=54106&p=889149#p889149
PostPosted: Sat Oct 23, 2010 2:43 pm
Is this only on the gy6 ruckus? How about the zuma swaps?
my ride.. viewtopic.php?f=92&t=50447
PostPosted: Tue Oct 26, 2010 7:40 pm
Sweet!
Don't sweat the C-clip too hard. For many years Jeep Wrangler axles were only held in by a C-clip at the spider gears in the center differential. If you snapped an axle on the trail your tire and axle assembly would just walk right out of your axle tube. Talk about scary!
My Build Project "Sukcur Punch"
PostPosted: Mon Feb 14, 2011 7:47 am
(last few pics)
i want that metal strap. think about putting these into production at all? so many people are swapping i'm sure it'd be a hot item.
My sad excuse for a build thread
PostPosted: Wed Feb 16, 2011 2:30 pm
I honestly don't think you will have a problem with the case cover in tact. The people who had the problems removed the case cover and lost the structural integrity=broken cases!
I just wanted to be safe!
:banger: :banger:
PostPosted: Wed Feb 16, 2011 8:28 pm
exactly, so do i - i dont have health insurance lol
PostPosted: Fri Mar 18, 2011 11:31 pm
im going to stay away from a fatty now even if its reinforced.
Im Soooooooo JDM my heart is on the far right side of my chest.
I Guess Its A Build Thread
PostPosted: Sat Mar 19, 2011 7:07 pm
uhg i just spent over a grand on all the shit to fatty gy6 my ruck (custom frame, 10x8, r1 shock, crate motor, etc...), and now im having second thoughts. faaawck.
PostPosted: Mon Jun 27, 2011 8:50 pm
same shit just happened to a homie, we were riding @ 45ish mph when he hit a bump and the case broke. he had no trans cover because he wasnt done polishing it. im doing the cut thing even tho im using the cvt cover
Modelo Bike thread:
viewtopic.php?f=92&t=77861
ChitownRuckus
HoodSetupCrew
 Post subject: Re: GY6 TECHNICAL SERVICE BULLETIN cracked left side case
PostPosted: Sat Jul 30, 2011 10:16 pm
roosterboyfred wrote:
This is very good info.Now, I'm not running a cvt cover, but do have the "Ankelbitter"cvt plate. It's 1/4 thick aluminum. I don't know if it will help so I guess I'll just have to keep an eye on the swing arm.
this does nothing .. mine cracked with the anklebiter ..
== Mini Moto Lab ==
http://www.minimotolab.com
Ruckus Parts for Canada, Eh! :canuck:
North America's HOTLAP Distributor
Northern Touch
PostPosted: Sat Jul 30, 2011 10:18 pm
HIgrade wrote:
anklebiter takes place of a cvt cover, 1/4" 6061 is more than enough.
this is incorrect!!! my cracked case is proof
RUN FULL CVT COVER!!
== Mini Moto Lab ==
Northern Touch
PostPosted: Sun Jul 31, 2011 7:34 am
Unless you plan on running without some sort of CVT cover you should be fine. That cover is an integral part of the swing arm removing it will cause your swing arm to not be as strong.
Replace it with one of the many options on the market may or may not cause it to crack, the one that are flat pieces with just holes for the variator and clutch should be fine. The ones that are all cut up with designs and shit I'd be iffy on though.
Runt
My runtuckus build thread.
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=59688
Need Turbo? I'm your guy.
http://www.forcedperformance.net
PostPosted: Sun Aug 07, 2011 9:49 am
So now that I'm almost done my gy6 and paranoid, can we get a count of how many people this has actually happened to? Not to say we are or aren't safe, I'm gonna check my shit DAILY!
"Pity Da Fool" Ruckus - frame-up build in progress
"Green Machine" Ruckus - SOLD
Yamaha FZ6R
PostPosted: Mon Aug 08, 2011 5:49 am
Would there be any way of reinforcing that right angle to stop or slow the shear force apart from just relying on the CVT? Just seems like a really poor engineering choice, like they started the rip for us. :?
Also, anybody ever added a right swing arm to a fatty conversion? Sorry, new guy
-Rob
PostPosted: Tue Aug 09, 2011 4:33 pm
Checked mine today....its cracked just like yours Higrade. Running short shaft, single shock, and no cover :(
Guess ill just have to buy a new case side and change my setup a little. Everyone need to read this while researching your swap plans!!!
Rucksters browsing this forum: Yahoo Wish It Was Google[Bot] and 4 guests
