Post new topic Reply to topic  [ 80 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: @@READ ME@@ GY6 TECHNICAL SERVICE BULLETIN
PostPosted: Sun May 02, 2010 7:53 pm
For those who are running a fatty tire, short axle, single shock, and no trans cover...or any combo thereof, be sure to keep and eye on your casing right in front of your gearbox. the factory 90degree casting is a flawed design and prone to crack when under excessive stress caused by us modifying.
i suspect this is a known problem in Asia as my replacement taiwan case has a relief cut out in this area from the factory to get rid of the sharp angle. id recommend doing this yourself with a 3/16" drill bit
Taxicabpete wrote:
Broken motor = broken collar bone
ckfishdive
_
 Post subject: Re: GY6 TECHNICAL SERVICE BULLETIN cracked left side case
PostPosted: Sun May 02, 2010 8:11 pm
:shock:
...PHX.602.RUX...
PostPosted: Sun May 02, 2010 9:12 pm
Scary stuff indeed! :(
Megatron
JETFIRE
A Good Quick job won't be Cheap.
A Cheap Good job won't be Quick.
A Quick Cheap job won't be Good.
PostPosted: Sun May 02, 2010 10:35 pm
WHOA! good info.
Killer Scooter welcomes you to the DARKSIDE!
キラー スクーター
Subliminal message of the Year: 2011 Ingenuity is the new Duplication
KILLER GOODIES
KILLER KRAFTED MACHINES
OG KILLER K125
PostPosted: Mon May 03, 2010 9:26 am
i broke alot of dio engines on my drag bikes. mostly from torque, on gy6 engines thats why i always tell everyone to use the right side brace. it does look alot better without it but its alot stonger with it.
SPREAD THE ALOHA!! no need be hawaiian for ALOHA stop the drama stop the hate.
PostPosted: Mon May 03, 2010 9:34 am
:ucrazy:
PostPosted: Mon May 03, 2010 10:58 am
HIgrade wrote:
hopefully someone will sticky this.
For those who are running a fatty flat tire, short axle, single shock, and no trans cover...or any combo thereof, be sure to keep and eye on your casing right in front of your gearbox. the factory 90degree casting is a flawed design and prone to crack when under excessive stress caused by us modifying.
AS popular these GY6 have become this thread should be a sticky in SOON.
Also the reason I will stay HONDA
49cc power
TR#930
I Don't Regret The Rules I Broke, When I Die Bury Me In Smoke...
PostPosted: Mon May 03, 2010 4:02 pm
i can tell you that i have broken more honda engines in half. at least 20 of them. but i do run alot of power. on honda engines and gy6.
PostPosted: Mon May 03, 2010 4:18 pm
so what should we do to prevent this from happening to us if we run a GY6?
www.myspace.com/beird
PostPosted: Mon May 03, 2010 4:29 pm
hi grade mentioned it above. Either keep your cvt case on or do the relief cut like his currently.
Megatron
JETFIRE
The Official Unofficial TR Sheriff!!
PostPosted: Mon May 03, 2010 4:33 pm
WOW!
anyone know if the GET motor has had any troubles like this? or the Zuma motors (zumakus)??
Gy6 so popular maybe we should do a warning on the gy6 swaps.
My Ruckus: http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=54160
- B.I.T.R.
The Bureau of Internal TRama
ruckus2009 wrote:
If he was some troll, I'd be with you- give him the boot. .
PostPosted: Mon May 03, 2010 4:40 pm
Nice find man, deffinatley something that needs to be addressed, thats scary as hell. Did this happen on a motor running no CVT cover?
Click Here for GY6 Fatty Mounts, Frames, and Custom Fab
2001 Honda Prelude - 700+ whp/500+wtq in full street trim
2001 Toyota Tacoma TRD SR5 - 5" of lift, stuffing 34's, full armor, locked
PostPosted: Mon May 03, 2010 4:43 pm
i have warned about this. use cvt cover at minimum, use the left side brace or risk it. up to you. for me I have children and a wife, i gotta think of them first.
I built 124cc dio af18 and af16 engines that broke in half while drag racing back in 1995. and broke other engines in half because we used to run half cvt covers to help cooling. but now i run the whole cover and if not i run a right side brace. just think of the torque and dierection and deflection. alot of unnessicary stress. and all scooter engines were not made for this stresses. i run a 232cc gy6 it has alot more stress than a stock 150cc. ever see my bikes without the right side? or cvt? nope.
PostPosted: Mon May 03, 2010 5:19 pm
This is very good info.Now, I'm not running a cvt cover, but do have the "Ankelbitter"cvt plate. It's 1/4 thick aluminum. I don't know if it will help so I guess I'll just have to keep an eye on the swing arm.
All the ways you wish you could be, that's me. I look like you wanna look, I fuck like you wanna fuck, I am smart, capable, and most importantly, I am free in all the ways that you are not viewtopic.php?f=92&t=40592
PostPosted: Mon May 03, 2010 5:47 pm
Oh, I"m running the GY6 pretty much the same as it came so I'm good? Minor mods, no fatty, mojo weld on mounts...nothing crazy
