Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: Length of shortcase vs longcase
PostPosted: Sun Sep 06, 2009 9:19 pm
So, I think I've F'ed up and got a short case engine. I thought I was getting a long case because the wheels are 13". Comparing pictures of short and long cases now, it seems long case have three bolts on top of the variator/CVT cover and short cases only have two. Mine only has two :pissed:
I've already ordered a Killer Scooter mount and I read on another thread that short cases won't work with this mount.
Can anyone confirm the length of the swingarm on either so I can measure mine?
07 Honda Ruckus (50cc)
06 Honda Ruckus (GY6 SWAPPED)
09 Harley Iron 883
04 Subaru WRX
08 Titus Motolite (mountain bike)
99 Bontrager b-29 (BMX Cruiser)
Loaded Dervish Longboard
 Post subject: Re: Length of shortcase vs longcase
PostPosted: Sun Sep 06, 2009 10:19 pm
Ok, after digging around some more, I found the measurments to what seems like a short case. Says on here that the distance from mount to shock mount on a short case is 16.5 inches. The one I have measures 18". Crossing my fingers that the Killer Scooter mount works!
http://www.rcepi.com/gy6_engine.htm
Maybe this should be a sticky. This is the only resource I've seen that shows the measurements of a Shortcase. Apparently you just can't go by wheel size anymore.
09 Harley Iron 883
04 Subaru WRX
PostPosted: Sun Sep 06, 2009 10:48 pm
More comparisons/resources
09 Harley Iron 883
04 Subaru WRX
PostPosted: Mon Sep 07, 2009 12:41 pm
What is the advantage/disadvantage to a long case over short case?
Also Ive heard that Bum's mounts are compatible with the short case. You shouldnt have any trouble selling a ks mount.
PostPosted: Mon Sep 07, 2009 3:17 pm
Don't know if this will help. I know it's just the covers to the crankcase but it does have the measurments. Sorry about the big pics.
Long Case.
Short Case.
"It's like the deadliest catch without the crabs."
PostPosted: Mon Sep 07, 2009 9:46 pm
The largest wheel you can fit on a short case is a 10 inch, which would be cool if you like the stock look, but the 130/90-10 (stock tire size) is too big to fit.
Also, a lot of people like that stretched out look, which the long case more easily facilitates.
PostPosted: Mon Sep 07, 2009 9:57 pm
Thanks scribble, that helps.
Colin - I thought that was the case too about the wheels. However, there's someone here in IL that bought the same brand I have (BKM) and it came with 13" wheels on his short case.
09 Harley Iron 883
04 Subaru WRX
PostPosted: Thu Oct 01, 2009 3:22 pm
what do you need on top of the short case engine to make it work for a swap.
everyone has long cases, and swap out the whole tire, or get a donor scooter and change everything from engine to shocks.
if I foudn a great deal on a gy6 short case.... what else do i need to make it work!
[]V[]addog
PostPosted: Thu Oct 01, 2009 4:30 pm
besides the ATR modification
that's the first I've seen of a disc brake gy6 like that
| STRONG BEACH | STANDARD FUNCTIONS | ATR | DROWSPORTS | RUCKSTERS | BOWLS | KILLER SCOOTER | AREA808 GARAGE | BTX METALWORKS |
Kidnapped
ahDAMN Bomb
kim jong ill: Too much hate from people who do nothing for the scene
DYR
PostPosted: Thu Oct 01, 2009 4:43 pm
I have some dope 12" wheels that I am pretty sure are for the short case; they look exactly like the wheels that Killer Scooter sells.
PostPosted: Fri Oct 02, 2009 6:45 am
so with a short case you need ot buy a rear wheel?
[]V[]addog
PostPosted: Wed Oct 07, 2009 5:25 pm
I own the 16" gy6 setup and everything is bigger and stronger on it. My buddy's 13 gy6 with quite a bit done won't keep up with mine in basic stock form. But alot is different and hard to find. But would be worth the money as gearing is way better...
 Post subject: GY6 Short Case vs. Long Case
PostPosted: Tue Nov 03, 2009 4:29 pm
What is a difference between short case and long case gy6 and its mounting? Why everyone goes for a long case engine?
 Post subject: Re: GY6 Short Case vs. Long Case
PostPosted: Tue Nov 03, 2009 4:31 pm
Short case only fit 10" wheels
The long cases can go to 13" wheels.
Long case stretch out the wheel base more.
Please Call to order 515-256-9062
NEW WEBSITE UP http://WWW.SCOOTERS4LIFE.COM
KS Power/NCY Project Zero Build
NEW Scooters 4 life Project LEFTOVERS
SUPPORT THOSE WHO SUPPORT THE SCENE
PostPosted: Wed Nov 04, 2009 4:22 am
and all the mount kits are designed for the longcase
Rucksters browsing this forum: Yahoo Wish It Was Google[Bot] and 2 guests
