Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: GY6 Swap harness onto Stock controls
PostPosted: Thu Oct 13, 2011 1:28 pm
i wouldnt
its possible but then you are putting a heavy load on the ignition switch itself
MY OLD 40K MILE RUCK
MY JANKY NEW BUILD
PostPosted: Thu Oct 13, 2011 1:51 pm
TT-350z wrote:
i wouldnt
I see
now to figure out why the key doesn't kill the engine....
My Build.
viewtopic.php?f=92&t=60955
PostPosted: Thu Oct 13, 2011 1:52 pm
wired like the pic it will
MY JANKY NEW BUILD
PostPosted: Fri Oct 14, 2011 5:33 am
Cool I'll work on that this weekend.
My Build.
PostPosted: Mon Dec 12, 2011 1:25 pm
Got any pics to replace bluesmoke's links that are dead? I could really use some pics/help wiring my GY, and other threads arent quite as explanatory. :meh:
1986 Elite 80 YT
1986 Elite 80 Slammy Hagar
2009 Kymco Agility 125
2013 Ruckus GET 50
PostPosted: Mon Dec 12, 2011 4:35 pm
Im all for this idea question what controls do people use instead of the stock ones?
PostPosted: Sun Sep 16, 2012 7:33 pm
A simple Thanks. Got it going with this guide :highfive:
My build(s) thread
New Stuff Fo Sale
PostPosted: Wed Nov 07, 2012 10:33 pm
Has anyone been successful with the fuel sensor using this method? I tried this method and it doesn't seem to work. The fuel sensor is not actually a float. I am no 100% sure what type of sensor it is, but it's definitely not a float. I have check resistance across the sensor and it fairly high when in the take (with fuel) when I pull it out of the tank the resistance goes up slightly.
Any tips would be helpful. If not I will have to dig deeper I guess.
Build thread: viewtopic.php?f=92&t=76000
PostPosted: Sat Jan 26, 2013 5:09 pm
This may have been asked before, but is this the same wiring for the Metro?
Thanks.
Build : viewtopic.php?f=92&t=84554
PostPosted: Tue Mar 05, 2013 3:13 pm
thanks this should help a lot when swapping mine, an save some money. :banger:
PostPosted: Tue Mar 26, 2013 4:44 am
Thanks.
Yup it has the same colors as the metro fuel sending unit. Green, blue/white and yellow/white I think ^_^ atleast mine's does ^_^
My Toys
2008 Toyota Tacoma TRD 4dr prerunner
2012 Piaggio Typhoon 125
2004 Metruckus
1987 Honda Elite CH150 (on hold Project)
Un428-1 Rebuilt viewtopic.php?t=66350
PostPosted: Sun Apr 21, 2013 8:29 pm
from my understanding the ruckus kill black/red and the ruckus ignition red/green to pole 7 on the relay is this correct?
My Ruckus Build
viewtopic.php?f=92&t=78272&p=1353911#p1353911
PostPosted: Sun May 05, 2013 5:08 pm
TT-350z wrote:
i have been asked this WAYYYYYYYY too many times before
so i went ahead and drew this diagram to simplify things
the colors for the gy6 seem to be the most common, yours may vary
this uses 2 SPDT relays, not the 1 radio shack relay
i have found these SPDT 12v 30-40amp relays for as cheap as $3 each
EDIT, THEY ARE EVEN CHEAPER HERE
http://www.amazon.com/VDC-Automotive-Re ... B0002KR9GG
with this setup your kill switch WILL WORK NORMAL, NOT BACKWARDS!!!!!!!!
i just did this today and it works. i have a 8 pole i think ^_^ my donor is a 2008 tank 150cc .when i take out the key it shuts off and when i turn off the kill switch it also shuts off.. oh yeah!! big mahalo..
fyi the black and white goes to the cdi..
My Toys
2004 Metruckus
PostPosted: Sat Jun 14, 2014 2:39 am
Are these still available?
