Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: GY6 Swap harness onto Stock controls
PostPosted: Thu Jan 20, 2011 7:19 pm
:banger: thanks for the idea i got my engine today and i hope everything works out find
Official Ride Game Judge!
PostPosted: Fri Mar 04, 2011 10:26 am
TT-350z wrote:
i have been asked this WAYYYYYYYY too many times before
so i went ahead and drew this diagram to simplify things
the colors for the gy6 seem to be the most common, yours may vary
this uses 2 SPDT relays, not the 1 radio shack relay
i have found these SPDT 12v 30-40amp relays for as cheap as $3 each
EDIT, THEY ARE EVEN CHEAPER HERE
http://www.amazon.com/VDC-Automotive-Re ... B0002KR9GG
with this setup your kill switch WILL WORK NORMAL, NOT BACKWARDS!!!!!!!!
question....what if you don't plan on using the kill switch? just something similar to the Magic Button for starting. i have never used my kill switch...not of the ruck or any of my big bikes.
how should it get wired then? do i just omit the kill switch wires?
the incredibly slow and cheap build: viewtopic.php?f=92&t=52401
the incredibly slow restoration build: viewtopic.php?f=92&t=56496
PostPosted: Fri Mar 04, 2011 10:29 am
yes just run that 2nd blue line in the pic to 85 on the bottom relay
very easy to omit the kill switch
basically the red/blue from the ignition to both 85's
MY OLD 40K MILE RUCK
MY JANKY NEW BUILD
PostPosted: Fri Mar 04, 2011 10:40 am
you rule brother! mucho grassy ass! :banger:
PostPosted: Fri Mar 04, 2011 10:45 am
no prob, pm me if u need any more help
MY JANKY NEW BUILD
PostPosted: Sat Mar 05, 2011 8:24 am
ok so i worked on the wiring last night in hopes of having the scoot ready for the daytona ride today but NO LUCK :pissed:
i wired it just like this and adjusted:
please not i'm not using a right control.....only a start button and a complete GY6 harness
here's what i noticed....i didn't have a black and white wire heading to the lower 87a so i traced the PINK wire back into the harness and found it was spliced into the b/w one...GOOD. i wired it up like you suggested and was able to get power to the harness (check output wires like tail light and such). went ahead and tried to start it but the starter solenoid wasn't getting any juice. looking closer i don't thing it was wired to the ignition. i had wired my starter wires into the relay. i removed them from the relay and hooked them up the yellow/red and black/white wires in the plug going into the gy6 right control and got the motor to turn over. GREAT!!!
now i'm not getting any spark. :x i swapped coils, CDI's with spares that i had and double checked the wiring in all that. i'm convinced it's in the wiring up front around these relays. maybe i need to bypass the kill switch....?????
PostPosted: Sat Mar 05, 2011 8:32 am
the bottom relay in the pic is strictly there to kill the engine, all power goes thru the top one
sounds to me like u hooked up the start button wrong
any black/white in that harness should be for kill, not starting
MY JANKY NEW BUILD
PostPosted: Sat Mar 05, 2011 9:15 am
wanna come over and help me? :mrgreen:
i hooked up the gy6 right control (which has the kill switch and is plug and play) and same results. i'm so confused right now
PostPosted: Sat Mar 05, 2011 9:16 am
lol u can bring it here
MY JANKY NEW BUILD
PostPosted: Wed Aug 31, 2011 8:59 pm
I'm in the process of revamping my handlebar and controls right now. I'll post pictures after I get mines up and running. But I am also on the killswitch issue, trying to bypass this thing.
I like cookies
My Ride
PostPosted: Wed Sep 14, 2011 10:59 am
Got my wiring done recently and found a super easy way to bypass my killswitch. I just wired the two wires to each other and thats it! I have the ATR harness and the plug where the killswitch wires normally go, I just used a U-wire and plugged it in place.
I like cookies
My Ride
PostPosted: Wed Sep 14, 2011 11:29 am
thank you
Stuff i sell http://diyruckus.bigcartel.com/
PostPosted: Wed Sep 28, 2011 8:58 pm
Thanks man Great write up!
PostPosted: Thu Oct 13, 2011 5:27 am
So I have a question, does anyone else have the issue with when the swap the gy6 in to their ruckus the key doesn't kill the bike? I can start my bike with the key in the off position. I'm going to do this so the kill switch works right, but any advice on the key issue?
Thanks everyone.
My Build.
viewtopic.php?f=92&t=60955
PostPosted: Thu Oct 13, 2011 1:05 pm
can't you just do it with one 5pin relay?
My Build.
