 Post subject: Stock Fuel pump with the GY6
PostPosted: Tue Sep 16, 2008 11:28 am
i have been searching (when TR doesnt time out LOL) and havent found much.
The only thing that needs to be done for the stock pump to work is to hook up the gy6 pulser wire(mine was blue/white off the stater then red/white after the plug) to the Ruckus pulser wire(blue/yellow) and the ecu keeps the pump running while the motor is running.
is about all i could find.
what kind of signal is the pump looking for? i see two wires, is it looking for a pulse wire and ground? what?
any help will be nice and hopefully when this place updates is bbs software and can search by subject it will be easy to find again LOL
Ruckus parts!
07 Honda Ruckus
08 Subaru STI
88 Toyota 4Runner
71 Toyota Fj40
PostPosted: Tue Sep 16, 2008 12:14 pm
There is a blue/yellow test wire that comes off the ECU. I use that wire as a signal for my tach. Connect that to the red/white wire off the GY6 stator.
PostPosted: Tue Sep 16, 2008 1:53 pm
ok, so the fuel pump is just looking for a pulse signal. as i have the blue/yellow wire from the doner scooter that went to the tach that i was going to hook up to my tach and i guess now also to the fuel pump :D
Ruckus parts!
07 Honda Ruckus
08 Subaru STI
88 Toyota 4Runner
71 Toyota Fj40
PostPosted: Thu Sep 18, 2008 3:18 pm
not using the stock ecu anymore. could you do me a favor and put a volt meter between the two post on the fuel pump when its working and tell me the voltage pulse? also, could you tell me if you know what one is the hot lead?
Thanks
Ruckus parts!
07 Honda Ruckus
08 Subaru STI
88 Toyota 4Runner
71 Toyota Fj40
PostPosted: Thu Sep 18, 2008 3:32 pm
Sorry.....don't have a volt meter.
PostPosted: Thu Sep 18, 2008 3:39 pm
doh
Ruckus parts!
07 Honda Ruckus
08 Subaru STI
88 Toyota 4Runner
71 Toyota Fj40
PostPosted: Tue Dec 30, 2008 11:13 pm
has anyone figured this one out yet. all i know that the stock ecu sends 5 pulses to the fuel pump (when you turn the key to the on position) to prime the bowl. after starting the pulse rate increases with rpm and only pumps gas when the float allows. was thinking of using a momentary switch to send 5 pulses manually before starting. what should i do...
PostPosted: Sat Jan 03, 2009 11:26 pm
i ended up just ditching it and getting a good vacuume pump. works like a charm
Ruckus parts!
07 Honda Ruckus
08 Subaru STI
88 Toyota 4Runner
71 Toyota Fj40
PostPosted: Sun Jan 04, 2009 9:33 am
can i ask which vac pump you used? and how thats running?
All the ways you wish you could be, that's me. I look like you wanna look, I fuck like you wanna fuck, I am smart, capable, and most importantly, I am free in all the ways that you are not viewtopic.php?f=92&t=40592
PostPosted: Tue Jan 06, 2009 7:31 pm
a big round one LOL i cant remember the name. however, its running like a dream :D love this thing with the gy6 setup
Ruckus parts!
07 Honda Ruckus
08 Subaru STI
88 Toyota 4Runner
71 Toyota Fj40
