Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: GY6 wiring: what wire does what? here is your answer
PostPosted: Sat Apr 21, 2012 9:02 pm
I'm trying to get my 11 pole GY6 build up and running. I've been poking around with my mulitmeter for 2 days now trying to wire up my 8 pole DPDT relay so I can try and crank this thing. I've listed out all the wires I have at the front of the harness. Can anyone offer any guidance? From reasearch, this ppicture is as far as I've gotten. :(
Connector 1, at front end of harness (C1)
RED - from + on battery
RED - no signal (connected to red wire above AND to the red/blue wire on the stock ruck ignition)
GREEN - ground
BROWN/BLK - to C2 (this wire doesn't go anywhere else... weird)
GRAY - to the gray wire on C3
GRAY - to rear lights (connected to gray above)
BLACK - to C2 and Rectifier
BLACK/WHITE - from CDI ("kill switch" pin out)
[RED/GREEN] - just chillin. stock ruck ignition wire.
Connector 2, at front end harness (C2)
BLACK - Rectifier + C1
BLACK - Rectifier + C1 (haven't joined these 2 black wires together)
YELLOW - to 3 pin connector on the rear of the harness (doesn't have anything to do with the CDI)
BLACK/YELLOW - to CDI and to coil for spark plug
BROWN/BLACK - to C1 (this wire doesn't go anywhere else... weird)
WHITE/BLUE - to the same 3 pin connector on the rear of the harness as the yellow wire on C2
Connector 3, at front of harness (C3)
GREEN - Ground
ORANGE - to a 5 pin connector on the rear of the harness (turn sigs?)
LIGHT BLUE - to a 5 pin connector on the rear of the harness (turn sigs?)
GRAY - to the gray wire on C1
ORANGE/RED - to starter solenoid
YELLOW/GREEN - to starter solenoid
Rectifier
PINK - from stator, and it's not connected to anything
BLACK, YELLOW, WHITE, GREEN, RED to the rectifier itself and another GREEN that's grounded.
#1 2007 Ruckus GY6 Project Pics fixed! UPDATED: 10/9/13
#2 2009 Ruckus Rolling Frame Project UPDATED: 4/2/12
WTB UPDATED: 4/3/12
PostPosted: Wed Apr 25, 2012 7:43 am
No idea about what you've got going on there, but I'm also trying to figure out the wiring on the 11 pole stator and rectifier. I got mine from Scrappy.
Here's the connectors...
Rectifier:
Stator:
The rectifier still has 5 wires and looks similar to others (like the one from Standard Functions - http://standardfunctions.com/store/inde ... ifier.html), but the wires are different colors and there's only one plug. Based on the similarities with the SF and other models, and wiring layout, would this wiring scheme make sense...
Rectifier:
Yellow, Black, White = AC in from stator
Green = Ground
Red = Pos battery for charge
Stator:
Yellow, Pink, White = AC to rectifier
Green = Ground
Blue/white = Trigger
Red = CDI charge
Both came from Scrappy, and both were sold specifically as 11 pole devices. They couldn't offer any assistance with the wiring, so I'm hoping someone here can help. In doing some extensive searching, there's mixed reviews, but the typical 3 yellows on the other stators seem to have been replaced with the yellow, pink, and white on this particular brand. And it's definitely an 11 pole stator btw. Would the colors on the rectifier go to the places outlined above? I'd like to get some sort of feedback before hooking it up and potentially frying something, then having to buy all new stuff again. Figured I'd post here before starting a new thread. Seems to be a lot of mystery to the different types of 11 pole setups that could use some clarification.
Thanks!
ElCapitan
Check out my turbo GY6 build!!!
PostPosted: Wed Apr 25, 2012 9:40 pm
^ EXACT same setup I'm running. Got it from Scrappy as well. I just have everything color matched.... but then the pink wire doesn't go anywhere, so that can't be right. Hopefully someone knows!
WTB UPDATED: 4/3/12
PostPosted: Thu Apr 26, 2012 5:02 am
I started another thread about it. Not sure how many folks still look through this one for anything but proven reference.
viewtopic.php?f=116&t=68754
So far, I've seen at least 3 different rectifiers that say they are for 11-pole, and at least 3 actual 11-pole stators that have completely different wiring. Oh so confusing...
ElCapitan
PostPosted: Thu Jul 05, 2012 11:56 pm
Wtf?!! Nvlqbzm Someone help first is my spark plug wasnt giving off spark fixed that issue now battery dies after sometime I went crushing today started it on off periodically (keep in mind it had died right before) so I put it on charger let it charge fully took off again stopped to eat get has etc.. No problem I get home and again it dies !!!!?????!? So I figure of I charge it again fully it will do it again turn on and off with no problem but I just don't want to be that one time I'm far away and no charger .. What's killing battery !?!?!?!? Suggestion anyone please
PostPosted: Tue Oct 30, 2012 6:34 pm
pictures on first page are broken?
viewtopic.php?f=94&t=77812
PostPosted: Tue Dec 04, 2012 6:10 am
Sledbrat wrote:
Just found this the other day, it was kinda helpful. Image
Ran the 11 pole stator red/black to Ruckus ignition kill then to #6 to have kill switch work correctly. No relay needed.
My build(s) thread
New Stuff Fo Sale
PostPosted: Mon Apr 01, 2013 3:44 pm
does anyone still have the pics to the first post?
 Post subject: 150 cc low fuel light
PostPosted: Mon May 20, 2013 7:10 am
Cound someone send me a link to how wire the light up tired of trying tp reprime the carb
http://www.flickr.com/photos/67145369@N ... hotostream my ride , gy6 motor, 09 GTR white paint, Brembo brakes, Yoshi carbon fiber exhaust, uri intake, mild stretch, lowered, password jdm straight bars Vienna va 22102
PostPosted: Wed Aug 03, 2016 8:27 am
Awesome information here
PostPosted: Thu Aug 04, 2016 4:00 pm
Anyone know what these wires would go to on my chinese gy6
Red[/Yellow - from solenoid
Green/Yellow - from solenoid
they are both wire into a 2 prong plug
