Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: GY6 wiring: what wire does what? here is your answer
PostPosted: Wed Jun 10, 2009 10:52 am
hey BSR
you should edit your tail light wiring part :lol:
for LED tail lights, people should run off DC and not AC
i burned mine out that way, and it looks like we may have another victim, el ruckuso
| STRONG BEACH | STANDARD FUNCTIONS | ATR | DROWSPORTS | RUCKSTERS | BOWLS | KILLER SCOOTER | AREA808 GARAGE | BTX METALWORKS |
Kidnapped
ahDAMN Bomb
kim jong ill: Too much hate from people who do nothing for the scene
DYR
PostPosted: Thu Jun 11, 2009 6:51 am
OK, if you have LED taillights, just run them DC instead of AC. yellow stator wire goes to headlight, stator, and autochoke, and taillight goes to switched DC.
PostPosted: Mon Jun 22, 2009 1:01 pm
I just started wiring up a gy6 and this has made it a lot easier, thanks to all who have contributed
04 ruckus
09 ruckus
you're just someone good to bite when i'm drunk
PostPosted: Wed Jun 24, 2009 8:44 am
:banger: welcome to the darkside...
"...it is what it is..."
***Sushi Boy's: 2009 swapACKUS in the WerX***
rfra446 wrote:
hells ya! puffy is the best thing to hit this place since chocolate milk!
FS: Must sell so I can rebuild my gy6... PRICE DROP!!!
PostPosted: Wed Aug 26, 2009 12:36 pm
YOU,
Trying to figure out, sort, understand, all of the BS in doing your own wiring harness.
BUY A WIRE HARNESS
BTXRUCK wrote:
you guys look like gangsters.... i dont know if i wanna associate with trouble makers.....
http://www.southbayruckus.com
http://www.vimeo.com/channels/94859
L.A.KINGS HOCKEY
PostPosted: Sat Sep 05, 2009 2:21 am
hi,
i bought a GY6 150cc long case
the stator wire on it
3 yellow on a separate plug and the other plug has
blue with a white stripe
black with a red stripe
and green
2 plugs total 3 wires each
rectifier that comes with it has 5 wires
black
red
yellow
green
pink
cdi has 6 wires total
first plug has 2 green, 1 light blue with white stripe, 1 black with yellow stripe
second plug has 1 black with white stripe and 1 black with red stripe
no white wires at all
i bought the harness from www.partsforscooter.com
and the GY6 motor from www.scooterworksusa.com-chicago
any help/info where this wires hook up to is very much appreciated....mahalo
PostPosted: Thu Oct 22, 2009 11:09 pm
Just found this the other day, it was kinda helpful. Image
NWRA - 33 Big Jerks
PostPosted: Mon Feb 08, 2010 4:59 pm
Just wanted to say thanks. With the help of this post she is up and running 1st go. too bad we are supposed to get a foot of snow tomorrow.
THE BUILD THREAD!!
05 ruckus
2012 CBR1000rr
92 gsxr 7/11
72 cb350 current project
67 ca110
64 ca110
PostPosted: Wed Apr 14, 2010 7:44 pm
Anyone have the original pictures?
Steve wrote:
Don't fuck up my beer!
Check out my ride! http://totalruckus.com/phpBB3/viewtopic.php?f=92&t=50174
PostPosted: Tue May 04, 2010 8:58 pm
ya, its a pic of a stator connector and a rectifier. I'll see if I have a scoot anywhere around that has a similar setup to upload another pic of, I didn't host the pics since I didn't have a camera at the time..
PostPosted: Wed May 12, 2010 4:21 pm
I need a little bit of clarification on a couple wires to help me finalize my wiring setup. I need a better understanding of the functions of the Black/White CDI wire and the RED Rectifier wire.
1. Does the Black/White CDI wire just control ground state? (In other words does it tell the CDI it is grounded or ungrounded to kill the motor?)
2. Is the Red Rectifier wire 12v DC lead? And does it go to direct or switched 12v DC? (In other words should the Red rectifier wire be connected to 12vDC power only when the ignition is on when other accessories like horn and speedo light are on or should it bypass the ignition and be connected directly to the 12v battery power at all times?)
Please help!! Thanks!!
My Build Project "Sukcur Punch"
PostPosted: Fri May 14, 2010 7:00 pm
Here is the wiring for a 5 wire rectifier. I bought mine from KS Power and got these details from Nick.
Left to right...
Black - 12VDC Monitoring wire (Connect to 12VDC feed to brake light or headlight)
Red - Battery (DC charging system wire)
Yellow - Stator (AC charging system wire)
Green - Ground
Pink - Stator (AC charging system wire, typically white on the stator)
* Monitoring wire checks the 12VDC system and raises or lowers 12V output based on the needs of your system so your battery doesnt overcharge or undercharge. This wire does not need to be hooked up but is recommended.
Red wire goes directly to a constant 12v to charge the battery
PostPosted: Wed Jun 16, 2010 3:37 pm
thanks for this awesome write up bluesmoke!
I got everything up and running, been riding for a week or two, but my led brake light just burnt up. :pissed: it's an r1 light so the turn sigs and running lights are all part of it, but they all work fine... not sure what caused this, as everything is running off of the red DC wire from the rectifier. :ucrazy:
180cc 'beast'
PostPosted: Wed Jun 23, 2010 10:54 pm
Is it possible to re-upload the images? Kinda sucks that there arent any pictures for reference. good job on the Write up would be perfect if the images were still there.
PostPosted: Wed Oct 27, 2010 10:54 pm
I'm in the process of running the wires through my rear frame, and am trying to eliminate some wires up front.....
There are green wires and orange wires coming out of the batt box that go from ONE wire to about 3 wires and run back to the taillights. Honda has a crazy-assed gold crimp connector making the connection?
Can't I just solder all three wires up in the box, and run ONE green and ONE orange back to the taillight? (i am using an R1 type LED light)
Thanks to all that can help!!!
"BlueBallz,Darkness,Scrappy,MetRuckus" projects!!
viewtopic.php?f=93&t=54106&p=889149#p889149
