Post new topic Reply to topic  [ 187 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13  Next
 Post subject: Re: GY6 101??? Edjumacate me...
PostPosted: Thu Mar 15, 2012 5:37 am
Are there different drum drake sizes on the 150 long case? I have a motor and the 13 inch 3 spoke wheel and the brakes are larger than the drum on the wheel.
MY SCOOT:
viewtopic.php?f=96&t=65200
SCOOT AND DESTROY HOODIES:
viewtopic.php?f=91&t=79168
PostPosted: Thu Mar 15, 2012 7:02 am
runtmasterflex wrote:
R-me-rnch wrote:
so if i buy an 11 pole stator for my gy6 can i run the stock flywheel or do i need to buy a new one ?
Well if you're going from a 6/8 to an 11 you'll need a lot more than just the stator.
Stator
Flywheel
Rectifier
and a harness that's wired to accept an 11 pole stator.
Runt
When I went from an 8 pole to an 11 pole set up I was able to use my stock flywheel... There are some stock flywheels that will not work with and 11 pole stator though.
My builds:
Red Rocket
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=63079
Peacock
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=64397&p=1089566#p1089566
MET MAGIC
http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=65346
PostPosted: Fri Mar 16, 2012 12:39 pm
From what I found out today it's a 13" for a 50cc GY6
MY SCOOT:
 Post subject: does gy6 150cc need case boring for 180cc
PostPosted: Thu May 10, 2012 2:22 pm
im looking to bore my 150cc gy6 to a 180cc.. i hear the case needs machining.. can anyone confirm this? thanks
first gy6 ruck
viewtopic.php?f=116&t=70121
10 - matte black ruck
12 - clone red ruck
07 - triumph daytona 675
11 - revtech 1801cc custom bobber (built/fabricated myself)
93 - red FD rx-7
04 - black lincoln aviator
 Post subject: gy6
PostPosted: Thu May 10, 2012 2:46 pm
who makes the best 150 cc gy6 and in genaral how many miles can yu expect from 1
http://www.flickr.com/photos/67145369@N ... hotostream my ride , gy6 motor, 09 GTR white paint, Brembo brakes, Yoshi carbon fiber exhaust, uri intake, mild stretch, lowered, password jdm straight bars Vienna va 22102
48hours of Ruckus Winner
 Post subject: Re: gy6
PostPosted: Thu May 10, 2012 2:50 pm
Ay dios mio.
I, uncle ruckus, wrote:
39,438 total miles Rucked.
mine viewtopic.php?f=96&t=31836
PostPosted: Thu May 10, 2012 2:55 pm
^my thoughts exactly.
DOUCHE #3; asshole extraordinaire. certified LEAN specialist.
ʞiller scooter - where we ʞill-her-cooter.
zeekusssss
Location: Dongguan, Guangdong. The Pooning capital of China
 Post subject: Re: does gy6 150cc need case boring for 180cc
PostPosted: Fri May 11, 2012 2:50 am
absolutely :happydance
180cc is 63mm
highest u can go without machining is 59mm (155cc)
For order inquiries add me to WeChat (phone app)
My WeChat ID is: poonparts
my builds
viewtopic.php?f=75&t=64592&p=1093876#p10933
 Post subject: Couple of random GY6 questions... PLEASE HELP!
PostPosted: Wed May 30, 2012 8:20 pm
Here is a list of things I could use some knowledge on. PLEASE HELP!
GY6 exhaust that's kinda quiet and affordable?
Good variator, rollers, and springs?
Any other good modifications to do...
Thanks for all the help, knowledge and ideas.
viewtopic.php?f=92&t=71070
 Post subject: Re: Couple of random GY6 questions... PLEASE HELP!
PostPosted: Thu May 31, 2012 3:23 pm
goatlover would know.
 Post subject: Is this a big bore or no
PostPosted: Thu May 31, 2012 5:47 pm
OK so I picked up a motor but upon looking at the the fins on the head where the sleeve is I noticed something the fins on every standard 150 I could find were straight, perpendicular to the direction of movement of the cylinder and all the big bore stuff were like a wave or some sort of pattern not so much straight can anyone confirm this otherwise I'm going to have to tare it down and use the calipers to find out
Sent from my Nexus S using Tapatalk 2
Gy6 Ruckus - Project Black Ice Sold
09 Zuma Stolen
Forza300 Swapped Ruckus
PostPosted: Sat Jun 02, 2012 8:25 am
any one know what im talking about????
09 Zuma Stolen
PostPosted: Fri Jun 22, 2012 10:39 pm
for improved airflow , may be a performance upgrade cylinder.
http://performancekote.com/
viewtopic.php?f=96&t=77312
PostPosted: Sat Jun 23, 2012 5:21 pm
Whoa, I can't believe I've never peeked into this thread before. May as well pick up some of the unanswereds.
PostPosted: Sat Jun 23, 2012 5:22 pm
djwimbo wrote:
time for another newb question.
Say I got a good deal on a shortcase with kickstart(seems harder to find) BUT it's the ATV setup, so it has reverse. Can I just remove the reverse stuff and run it like any other GY6? I don't see any physical differences other than the gearset bolted on the output of the trans.
If the engine has an external reverse box, you can remove it easily and mount your 10" GY6 scoot rim & tire where the reverse box was. Here is an example of an external reverse setup:
However, if it has an internal reverse built into the engine case, it's not a good candidate for a swap. Here's an example:
