Post new topic Reply to topic  [ 187 posts ]  Go to page 1, 2, 3, 4, 5 ... 13  Next
 Post subject: GY6 101??? Edjumacate me...
PostPosted: Thu Aug 28, 2008 8:07 am
Please forgive the noobinian nature of this question...and before the forum gestapo take me out back and beat me with a rubber hose... yes, I did trying doing a search. (Maybe not as deep as I should have...)
So my question: Do we have a "GY6 101" for those of us not as seasoned to the world scooter motor swapping?
I'm sure I'll eventually catch up from all topics being posted, but it would be great to have a place to start. I've read the wiki on the gy6, but would love to read on the specific application to the Ruckii...
OK... now that I've mustered up the courage to ask the freshman question, I shall go back to the pit of noobs and cower in the shadows of the scooter elite.
2010 Aprilia SR50 R Factory Replica Sbk
"When I had a lot, I gave so little. Now that I have so little I want to give so much. Please donate to a good cause today." - Mike Tyson
PostPosted: Thu Aug 28, 2008 8:35 am
i haven't seen any. just lots of little bits all over. makes it hard to figure out. but i will be picking up a few gy6 scooters next weekend and plan to document all my swap so hopefully that will work :D
Ruckus parts!
07 Honda Ruckus
08 Subaru STI
88 Toyota 4Runner
71 Toyota Fj40
PostPosted: Thu Aug 28, 2008 8:36 am
:D
Not a totally noobian question, but more specific information your seeking would be helpful.
Have you looked in the motor swap section yet?
Seems like it's overrun with GY6 questions and info nowadays as thats the main swapakus of choice right now.
PostPosted: Thu Aug 28, 2008 9:07 am
tomtom wrote:
:D
Yeah I read a few topics in there, but got intimidated by all the jargon... after a while I just gave up.
Here are a few my basic questions (I'm sure more will come up as I continue to learn):
- What is the GY6 engine? How big is it (cc's)?
- How much power gain?
- What are the other mods needed to be done to accommodate said engine (new mounts, any custom fab, etc.)? If not, is it a direct bolt on swap?
- Aside from increased speed, what other characteristics change? Drivability, etc.?
Thats it for now... I hope I didn't post this in the wrong section...
PostPosted: Thu Aug 28, 2008 9:56 am
The GY6 swap has not been fully documented, and the info that is available is spread out amongst numerous threads here.
The GY6 engine is rated somewhere between 7 & 11 horse power depending on the scooter manufacturer.
You will need a new mount to hang the engine correctly, and then you will need to create a hybrid wiring harness using the Ruckus & donor scooter in order to have all the electronics & such work
The Gy6 engine ranges from 50cc to 150cc depending on the donor. You will want the 125cc or 150cc engine if you are swapping, and you will want a donor scooter that comes with 12" or 13" wheels - the 10" wheel donor scooters have a slightly smaller (dimension wise) engine & that makes it harder to swap & you will be stuck using really small wheels & tires.
Can't tell you about the driving characteristics because I haven't swapped yet. I can tell you that the GY6 has TONS of mods available from big bore kits, to stroker cranks, to variators, etc
Hope that helps....
PostPosted: Thu Aug 28, 2008 10:43 am
This information may be a little off so please correct me if I'm wrong.
- The GY6 motor is off a Chinese/Korean scooter. The most popular one for the Ruckus is the 150cc which can also be bored out.
- Power can range from 8.5 to 11 hp depending on your mods. Probably more by now. Tallkyle for example, put a turbo kit on his!!! :shock:
There's many mods you can do to the GY6 so power will vary.
People hit over 60mph with a stock motor with just a CDI and variator.
- You need new mounts/adapters. If you can't fab them yourself, PM members BATMAN or RUCKUS, or get a NCY extension kit.
- The last question, I'll leave it to a GY6 owner, since I don't have one (YET). Definately faster than the stock 50cc though.
PostPosted: Thu Aug 28, 2008 10:48 am
Killer Scooter's:
http://totalruckus.com/phpBB2/viewtopic.php?t=11655
Batman's mounts:
http://totalruckus.com/phpBB2/viewtopic.php?t=21074
Lazy to look for more links... do your own search!!! :lol:
PostPosted: Thu Aug 28, 2008 5:58 pm
I know that Honda made them originally and they started making knockoffs elsewhere but was the original HONDA GY6 the Elite 125/150 engine?
PostPosted: Thu Aug 28, 2008 6:19 pm
The elite had a vertical cylinder, not a horizontal like the Ruckus and GY6 swaps.
My Express: Midnight Express
PostPosted: Thu Aug 28, 2008 6:21 pm
What were the original HONDA made GY6's in then?
PostPosted: Thu Aug 28, 2008 6:53 pm
None that nobody really knows of. The 80's honda scooter motors were all vertical to my knowledge, but if anyone knows what the gy6 was in, please post.
RUCKUS DAY- April 15th!!!
viewtopic.php?f=95&t=99
PostPosted: Thu Aug 28, 2008 10:17 pm
To my knowledge Honda had made the GY6 engine for the Asain Market scooters, then the chinese started to re-produce them.
ALOHA! :wavehello
MAKOA SCOOTERS
PostPosted: Fri Aug 29, 2008 1:08 pm
what about the ecu? do you use the ruckus one or the donor scoot? :oops:
PostPosted: Fri Aug 29, 2008 4:28 pm
You don't use the honda ecu. But I left it in to work the low fuel light. If you remove the honda ecu you won't have a working low fuel light. The gy6 don't have a ecu. The gy6 only has the cdi and rectifier.
Its not what you buy! Its what You build!!!
06 187cc gy6 ruckus
08 gy6 ruckus (wife's ruckus)
05 gsxr1000
PostPosted: Fri Aug 29, 2008 5:06 pm
Actually I'd love to see a pic of a GY6 with a Honda stamp on it. I've always taken it at face value that it was a Honda design, but where are all the Honda GY6 motors? Honda is the largest manufacturer of motorcycle engines in the world, and they build shit that lasts... so where are all the Honda stamped GY6 engines? A Honda made GY6 would be sick in a Ruckus :ninja4
El Guapo - Morphous - MP3 - CH250 - Videos
How do I fix my ruckus, change my name, vote, sell, get my own section, complain...
