Post new topic Reply to topic  [ 770 posts ]  Go to page 1, 2, 3, 4, 5 ... 52  Next
 Post subject: Post here for 'is this a good gy6 swap motor/donor bike'
PostPosted: Sun May 18, 2008 8:48 pm
Please post this often asked question here so we don't have 10 separate threads asking the same thing.
One of my rides
PostPosted: Wed May 21, 2008 7:57 pm
Anyone know how difficult it would be to adapt the GY6's rear disc brake when doing the swap?
Pics!
Image[/img]
PostPosted: Wed May 21, 2008 9:08 pm
You just need the proper length rear brake line, and use the master cylinder hardware off of the donor bike.
One of my rides
PostPosted: Thu May 22, 2008 3:48 am
i yanked the whole line and shit off my donor.. Everything bolted on and it was near perfect length.
PostPosted: Thu May 22, 2008 6:12 pm
malone wrote:
Noun: Donar downaa(r)
1. The Teutonic god of thunder; counterpart of Norse Thor :?:
Well put. here is my how-to on swapping. buy two vehicles. take all the crap off one and install on the other. listen to girlfriend/wife whine about parts of vehicle everywhere for a few days/weeks/years. drive swap.
oh yeah, Thor>Donar.. If you are not ready to do a swap, don't do it!
PostPosted: Sun Jun 01, 2008 8:45 pm
I think Vento and Sunl along with TGB are the most commonly known gy6 variants.
One of my rides
PostPosted: Fri Jun 06, 2008 8:03 am
this is prolly a n00b question but could you use a quad engine?
PostPosted: Fri Jun 06, 2008 8:55 am
Sure, just have to figure out how to mount everything up. Anything is possible, it's just time and money + skill.
One of my rides
PostPosted: Fri Jun 06, 2008 3:59 pm
Time: NOT SO MUCH
Money: EVEN LESS
Skills: DON'T EVEN ASK
Money is all you need to make anything happen. You don't have that then you don't have nothing.
You could have time but no skills / money, you can't make it happen.
You could have skills but no time / money, you can't make it happen.
But if you have money but no time / skills, you can pay someone who does.
:lol: :lol: :lol:
RUCKSTERS
gAME FUCKiN oVER
2TR
PostPosted: Fri Jun 13, 2008 7:49 am
anyone know if this is ok to use
http://www.longboamerica.com/p_motor_detail.asp?id=125
is it ok just to run just the one sided swing arm when you do the swap?
www.THESPEEDLOUNGE.COM
my '07 build thread
viewtopic.php?f=6&t=30680
PostPosted: Tue Jun 24, 2008 1:22 am
IS THIS THE CORRECT GY6 MOTOR?
this is the info posted by seller
VIN: ASSIGNED
Warranty: Existing
Vehicle title: Clear
Condition: New
Engine Style: Single cylinder,4 stroke,air-cooling
Displacement: 150cc
Engine Type 157QMJ
Bore x Stroke:57.4*57.8mm
Compression Ratio:9.2 :1
Max Power:6.5kw/7500r/min
Ignition:CDI
Strting Mode: Electric and kick starter
Wheel Base:1280mm
Dry Mass:205 lbs
Ground Clearance:95mm
LxWxH:1880x730x1050mm
Clutch:Dry,centrifugal
Gear:CVT Bandon Belt
Front/Rear Tire:130/60-13-4PR
Battery:12V
Front brake:Hand operation,disc
Rear brake:Hand operation,drum
Max Speed: Up to 100km/h
Economic Fuel Consumption:3.2L/100km
Max Load:264 lbs
Fuel Tank:5.5L
Wheel:Aluminium
it says it has the 13" wheel but when i called he changed his mind twice...first it was a 10'' wheel then it became a 12" wheel
PostPosted: Tue Jun 24, 2008 7:41 am
slowpokeruckus wrote:
that looks like a short case gy6
2003 Ruckus...Sold
2000 Kawasaki Ninja...Sold
2009 Triumph Speed Triple
PostPosted: Tue Jun 24, 2008 7:44 am
http://cgi.ebay.com/ebaymotors/Metro-Deluxe-Moped-scooter-150cc_W0QQcmdZViewItemQQcategoryZ6722QQihZ006QQitemZ160252724861QQrdZ1QQsspagenameZWDVW
is this good?
that looks like the one i used
2003 Ruckus...Sold
PostPosted: Tue Jun 24, 2008 9:50 am
at this point i think the ad duped me into thinking it was the long case due to the info about the wheel size...ive won the auction but he has ran out and is waiting on a shipment already ported just waiting on customs paperwork to clear.
i told him that i do not want the 10" wheel but rather the 13" wheel so he recommended to me that i go to the warehouse and check out his stuff..ill let you know how it goes on either friday or monday...
PostPosted: Thu Jun 26, 2008 7:17 pm
Does longcase and short case just mean how far the wheel will sit back basically? Are the engine mounts going to be the same on the longcase as well as th shortcase???
04' scion xb, soon 18s with 2" drop
99' honda dio 50- stripped down tuning
soon to be 2008 ruckus 50
