 Post subject: Any suggestions on how to fix this? (variator related)
PostPosted: Fri Apr 12, 2013 4:13 pm
Went to change out weights/variator.
Nut came off easy... Way too easy then I found this.
Uber suprised the nut stayed on there this long, I tried to re tighten and it would tighten up but flies off after start.
Open to suggestions... (Preferably semi-cheap ones :D )
__________________________________________________________________
http://totalruckus.com/phpBB3/viewtopic.php?f=200&t=91419 dB's Grom Build
http://www.totalruckus.com/phpBB3/viewtopic.php?f=92&t=80035 Noob ruckus build thread SOLD
 Post subject: Re: Any suggestions on how to fix this? (variator related)
PostPosted: Fri Apr 12, 2013 4:16 pm
I don't thnk you can rethread the crank so you'll either need a new crank or a new engine
-Ruckus
-Big Ruckus
-Grom
PostPosted: Fri Apr 12, 2013 4:21 pm
Was afraid of that... I'm going to try to get another nut and rethread if no one suggest something else before I go that route.
PostPosted: Fri Apr 12, 2013 6:41 pm
ive heard of people stripping the splines from not installing the variator right and every person that has done that has either had to by a whole new engine or the crank but requires lots of work to get it going back again.
if you have been messing with the variator prior to this then you fucked up, and if you didn't then the previous owner/Mechanic did not know what they were doing.
Anyways you can probably get by, by rethreading it with a smaller nut but just be careful not to touch the splines OR get a new crank OR new/used engine.
My Mild Build Thread #2
PostPosted: Fri Apr 12, 2013 6:47 pm
If it were me, I'd try rethreading it first, considering that your other options kind of suck. Hopefully it works out.
In for pics!
CCON 2013 OBX
PostPosted: Fri Apr 12, 2013 7:20 pm
Today was the first day I've cracked open cvt. Im going to try and rethread with smaller nut then all else fails ill buy a crankshaft.
Anything you guys recommend changing also if i tear it down to change it.
PostPosted: Fri Apr 12, 2013 7:29 pm
try new marketing............steady garage!!
PostPosted: Fri Apr 12, 2013 8:19 pm
depending on your mileage...
PostPosted: Sat Apr 13, 2013 12:19 am
if your gonna replace the crank might as well go BB :meh: sorry to hear that though man :/ but id definitely try to rethread as well, maybe take it to a machine shop and see if they can do anything more... professionally if you know what i mean :/
My Ruckus Build
viewtopic.php?f=92&t=78272&p=1353911#p1353911
PostPosted: Sat Apr 13, 2013 12:29 am
good exscuse for a big bore and cam and port an polish the head :banger:
my build thread
viewtopic.php?f=95&t=79934&p=1376266#p1376266
Appear interested when not and vice versa ..... sun tzu
PostPosted: Sat Apr 13, 2013 12:31 am
Bb ftw.
AZ RUCKSTARS
BLVCKworks Products//CNC
viewtopic.php?f=90&t=91856
PostPosted: Sat Apr 13, 2013 5:16 am
Yeah, that's what I was thinking. It just kills me to have it sitting in the building and its finally nice outside, plus funds are practically non existent at the moment.
I agree with you guys, if it needs a crank it will get a lot more when it gets cracked open. Just trying to weigh my options, because I literally live in crater hole so no shops around to do anything so I will basically have to ship my stuff to get it done. So I would want to ship to one place that could maybe do it all.
I don't mind the tuning part with the big bore, that's what I got you guys (and girls) for :lol:
PostPosted: Sat Apr 13, 2013 9:38 am
Everying pictured below for $145
Anything else you guys think ill need?
PostPosted: Sat Apr 13, 2013 10:13 am
A tuna sandwich.
CCON 2013 OBX
PostPosted: Sat Apr 13, 2013 10:29 am
I_Am_Swol wrote:
A tuna sandwich.
Haha... Not a big fan of tuna. Just wondering that since it was in decent running condition (besides a little idle lope at first start up which smoothed out as it warmed up) but with 3k on the clock was wondering what else I should look into.
If I don't come up with a plan then, it will literally set for months until I can afford a 66cc engine, and as much as I would love to have a big bore. I would rather be riding it.
