Post new topic Reply to topic  [ 286 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20  Next
 Post subject: Re: 49cc & PROUD!..............(Specs pg.1) Whats your GUT ICON?
PostPosted: Mon Sep 29, 2014 3:17 pm
Weight: 165lbs.
Year: 2003
Miles:unknown
Performance Mods:
Shaved Drive face
5g roller weights
home made Intake
Home made exhaust
Cosmetic Mods:
Lowered Seat
drag bars
Kijima Headlight
relocated tail light
6.5in stretch
Tire Specs: (Front 100/90-10) (Rear130/90-10)
Top Speed: 53mph GPS Confirmed both directions on flat land with no wind. (the proper way to test) 55mph with slight tailwind
Average Cruising Speed: 45-50mph untucked sitting up.
Elevation:15ft above sea level
Environmental Conditions:85f 70-80% humidity
http://i6.photobucket.com/albums/y208/j ... 462c86.jpg
with tailwind:
Ruckus 49cc GET - 56mph GPS
Vento 172cc GY6 - 81mph GPS
PostPosted: Sat Dec 06, 2014 8:44 pm
Weight:
138lbs.
Year: 2005
Miles: 6,400 Date (12/6/2014)
Performance Mods:
Polini Variator
Daytona Drive Belt
rollers 5.5g
K&N filter straight on carb
MRP exhaust
Daytona CDI
38/75 Jets
Cosmetic Mods:
BMX stem
MTB riser bar
Ruckus swing arm
Tire Specs: (Front 110/80-10) (Rear 130/90-10)
Top Speed: 52mph @ 8800rpm drafting(GPS Confirmed)
Average Cruising Speed: 41mph seated straight up position, no drafting (gps confirmed)
Elevation: ______ above sea level
Environmental Conditions: Flats
 Post subject: Re: GET 49cc & PROUD!..............(Noob Specs)
PostPosted: Sun Dec 21, 2014 6:03 pm
Zombiefying this thread. The girlfriend and I decided to GET with the program last month.
Image&Image
Weight: 150, 250 with the significant other on also.
Year:2014
Miles:325 and climbing
Performance Mods: None
Cosmetic Mods: None
Utility Mods: None
Tires: Stockers
Top Speed: 42mph slight downhill
Average Cruise Speed:35-38mph flat (stock speedo)
Environmental Factors:All riding so far done at 20-45 degrees at best. Some hills around here where I drop to 25mph. Elevation ~1000ft.
Engine seems boggy in this cold, especially at higher speeds. Will start modding and tuning as weather and wallet permits.
PostPosted: Tue Dec 23, 2014 10:21 am
Image *UPDATE*
Weight: 148 lbs.
Year: 2009
Miles: 1,9085. Date:(12/23/2014)
Performance Mods:
MNNTHBX exhaust
5.6 roller weights
Blue clutch springs
Polini Variator
NCY CDI Unlimited
Velocity Stack air intake
Cosmetic Mods:
Gokubuto Fatty
10x8 Douglas
Lower stock forks by (Mike155cc)
Lowering handle bars
Lower seat
Tire Specs: (Front 100/80-10) (Rear 130/90-10)
Top Speed: 46mph (GPS Confirmed)(UPDATED) Can go faster.
Average Cruising Speed: 40mph
Elevation: 410 feet above sea level
Environmental Conditions: Sunny, 68-75 degrees average
My ruckus build: http://totalruckus.com/phpBB3/topic.php?f=96&t=91308 retired
PostPosted: Sun Feb 01, 2015 6:17 pm
Weight: 148 lbs.
Year: 2013
Miles: 447 (Feb-2-2015)
Performance Mods:
stock header to B&S exhaust
DIY Rad intake, UNI Filter
Stock jets
NCY unlimited
Shaved Drive face
Polini Variator
4.8 roller weights
Cosmetic Mods:
Dorbyworks 12" Stretch
12x7 rear fatty
Just4Show Lowered forks
Lower seat
Tire Specs: (Front 90/90-10) (Rear 140/70-12)
Top Speed: 54mph (GPS Confirmed, Drafting)
Average Cruising Speed: 46-49mph
Elevation: sea level
went for a ride to the gas station,
PostPosted: Fri Feb 20, 2015 11:45 am
PERFORMANCE MODS
POLINI VARIATOR W/ 5.5 GRAM SLIDER WEIGHTS
POLINI BELT
CUSTOM INTAKE w/ K&N FILTER
NCY CDI
REJETTED CARB
AFTER MARKET EXHAUST PIPE HEAT WRAPPED
(HONDA STICKER)=1HP
COSMETIC MODS
MICHELIN BOPPERS
LOWERED SEAT FRAME
NCY FOOT BRACE
HEADLIGHT LED BAR
CARBON FIBER HANDLE BARS
NCY GRIPS
LICENSE PLATE RELOCATION
FLUSH MOUNT TURN SIGNALS ON BATT. BX
R6 REAR TAIL LIGHT
AFTER MARKET REARVIEW MIRRORS
MOJO MOUNT-12.5" STRETCH
12"x8" FATTY
RRGS FORKS
TRS LOW BOY REAR SHOCK
I am a 300lb guy at about 2900 ft above sea level here in west Texas and I get my ruckus up to about 44mph on a long straight away. Cruise at about 37-40 mph.
2013 Honda Ruckus
GET motor
PostPosted: Mon Mar 16, 2015 8:56 pm
2012 FI zoomer.(import)
Performance mods:
Polini variator/stock weights
Daytona Belt
Custom intake
Two brothers exhaust
Ngk high heat range iridium spark plug
Michelin boppers
Cosmetic mods:
Mojo customs ten inch stretch
Mnnthbx seat frame
Ncy frame brace foot area thing
Pwjdm foot pegs
Up and tucked tail light
Composimo headlight lowering stuff.
Michelin boppers
Rrgs front forks
Atomlab handlebars
Pwjdm handlebar holder thing
Pwjdm front wheel spools and various gold bling bling.
Ripoff cycle gear bar end mirror that sounds like a bag of nickels.
210 lbs.44 mph long flats,cruise at 38-40mph.
Sorry no photos I ain't touched photobucket or any of that since the last decade.
stop drop and roll don't work in hell.
2012 zoomer.FI GET.
PostPosted: Wed Apr 01, 2015 10:59 am
04 ruck stock internals
Rider weight 180lbs
mods:
Sink pipe Intake mod
Met gears
120/70/10 rear tire
Ncy cdi
Webikes GP ehaust
Polini variator 5g dr.p sliders
Gates belt
Carb rejetted 38sj 80mj
Shaved stock drive face mod
Tto tach
Lowered seat frame
9.5" stretch
Drag bars
NOS bottle coolant tank
Cruisin speed 40-44 rolling terrain
50+/- full ruck tuck
PostPosted: Wed Apr 08, 2015 6:06 am
Weight:
166lbs.
Year: 2015
Miles: 480 Date (04/08/2015)
Performance Mods:
NONE not even checking the stock oil level as im close to a change.
Planned
Polini variator
Polini belt
Modified airbox
k&N filter
High speed spark plug
Refill with less oil(mobile 1 or Royal purple)
Cosmetic Mods:
Led headlamps
Planned
NCY shock/ Fox/
NCY fork/mod stock
digital gauges
Paint battery box blue
Rear rack
Perilli SL60/26
Tire Specs: (Front 120/90-10) (Rear 130/90-10)
Top Speed: 45mph (GPS Confirmed or Stock Speedo)
Average Cruising Speed:40mph
Elevation: 765 above sea level
Environmental Conditions: 66F
PostPosted: Fri Jun 05, 2015 12:15 pm
Weight: 195lbs.
Year: 2009
Miles: 2225 Date (06/05/2015)
Performance Mods:
Polini variator w/6.3g rollers
No airbox
UNI pod filter on OF intake
Iridium Plug
Yoshimura stainless exhaust
Dynatek CDI black box
38SJ/75MJ
Cosmetic Mods:
PWDJDM 6.5" extension
Trimmed rear fender
Daytona Drag front fender
NCY forks and rear shock
NCY rear wheel with Pirelli 120/90R10
Stainless tank cover
removed plastic rear frame cover
front pegs
lowered seat bracket
Kujima handlebar mount and kickstand
Removed center stand
shaved rear tail-lamp bracket, installed R6 rear light and small led front winkers
Renthal handlebars
Custom cupholder and license plate bracket
Tire Specs: Front 120/90-10(stock) Rear 120/90-10(SL26)
Top Speed: 47mph (GPS Confirmed)
Mileage:83mpg
Average Cruising Speed:40mph(I don't tuck)
Elevation: 5-200' above sea level(never out of sight of the ocean)
Environmental Conditions: 50-65*F, lots of rain
My main build is a 2009 Ruckus
My son's 2002 Metruckus
2002 Bajaj Chetak
1979 Vespa P125X(150cc) 2T
1966 Yamaha MG1T 80cc 2T
PostPosted: Tue Aug 04, 2015 8:48 pm
weight: 64kg
year: 2007
date: 4/8/2015
miles: 23,335km
performance mods:
leo vince exhaust
dynatek cdi
carb jets 38/82(keihin)
mnnthbx intake
mnnthbx dorf
mnnthbx skid plate
mnnthbx kickstand
mnnthbx dingleberry
mnnthbx turtlehead
mnnthbx front springs
mnnthbx indicators(k&s)
mnnthbx mirrors(driven)
mnnthbx bars
mnnthbx stem
mnnthbx grips(progrip)
mnnthbx throttle(g2)
mnnthbx sticker on left side(big time small bore)
doppler shock
composimo cvt cover
k&n drycharger
passwordjdm carbon fibre radiator intake
passwordjdm frame sliders v1
jspec rear fender mount
jspec pcv relocation
jspec headlamp bracket
jspec stuff&things
gates kevlar belt
6.9g rollers(polini)
cosmetic mods:
mnnthbx bar ends
composimo ignition cover
passwordjdm coolant tank
passwordjdm axle spools
tyre spec:
front: pirelli sl26 120/90/10
rear: michelin bopper 130/90/10
top speed: 78.8kmh (gps app on iphone)
average speed: 70kmh
altitude: 45m
environment: 32c no wind
PostPosted: Sat Nov 28, 2015 9:07 am
Weight: 170lbs.
Year: 2004 Metropolitan
Miles: 6,000
Tire Specs: Front 90/90-10 (stock) | Rear 120/90-10 (Michelin Bopper)
Top Speed: 50 mph (GPS Confirmed)
Average Cruising Speed: 45 mph (I don't tuck)
Environmental Conditions: 70-80*F
Performance Mods:
HD Velocity Stack
38/80 Jets
B&S Exhaust on Stock Exhaust Header
Michelin 120/90/10 Bopper
Polini Variator (with super secret mods)
Gates Belt
5,000 RPM Clutch Engagement Springs (i cant remember which color)
NCY CDI
Cosmetic Mods:
Custom Army Theme Paint
OEM Luggage Rack
R6 Taillight
LED Turn Signals mounted in front fender
NCY Lowdown Shock
Vans Grips
Left-Side Bar End Mirror
Stock Speedo LEDs
Trailtech Tachometer
Cell Phone Grocery Bag Mount
Ruckhouse Fully Adjustable Tag Mount
eBay Anklebiter CVT Cover
LED Headlight
Ryans GY6 Met Build
Parking lot mechanic
PostPosted: Fri May 05, 2017 4:22 pm
Greetings from Slovenia/Europe and nothing fancy but (I think) the only one in my country! :D
Zoomer PGM-FI
Weight: 186 lbs
Year: 2005
Miles: 10.200 km
Performance mods:
Still stock engine ('coz of so strict road laws)
Cosmetic Mods:
- TheRuckShop Original Gangsta stem
- Koso DB02 R speedo (pic - test fitment on mount)
- TheRuckShop 6.5" stretch kit
- TheRuckShop LED relay
- Pswrdjdm washer with inox bolts all over
- Pswrdjdm axle spool
- Pswrdjdm foot pegs front and rear
- Fehling clip-ons
- Stage6 F1 mirrors
- Mojo Customs wheel inserts (rear set still to be dry)
- Ooracing foot rest + custom made front foot pegs mounts
- Webike extended tank cover
- Sickspeed ultra low seat frame
- Buzzetti Ruckus sidestand (2 cm shortened)
- NCY extended throttle & brake cables
- ScooterNerds 3D printed radiator cover/intake/scoop
- cnc grips
- cnc bar ends
- speedo mount designed by me
- carbon fibre ring below stem (to cover triple tree)
- mini side marker lights
- tach/hour meter
- D1 Thermost radiator cap
- Sparco (green) tow strap
Waiting:
- NCY rear shock
- NCY (under seat) cover
- Atlas white walls
- Boppers front & rear
Found nice set of Honda Dio wheels for $40 but not sure if those would fit.
Eliminate any talk of functionality since it’s irrelevant to my needs!
PostPosted: Mon Jul 24, 2017 6:29 pm
New to the Ruckus game, coming from 1978 mopeds.
Weight: 155 lbs.
Year: 2016
Miles: 1000
Performance Mods:
5.5 Gram Sliders
K&N air intake kit
38/78 Jet
Polini variator
Polini Blue srping
Blue Clutch springs
Polini performance belt
NCY CDI unlimited box
Cosmetic Mods:
Low Down handle bars
gas tank cover
low down seat
Tire Specs: Stock
Top Speed: 41 mph Stock Speedo
Elevation: 16 feet above sea level (Florida) above sea level
So all this info leads me to ask the question,
with all that being said why am I still at 40 mph when others are running 45 mph?
Little background information, I am not a gear head but I do dabble often, I frequent the local Moped/scooter club ( im the only one with a ruckus) and learn a ton from them. I have had 4 mopeds all built by me and made to go 45-50 (which is sketchy when they were made in the 1970's) I now have recently switch to the ruckus family and finding these things much more difficult than I anticipated.
Any and all Information or help on getting my Ruckus up to the 45 mark would be greatly appreciated. 8) 8) 8) 8) 8)
PostPosted: Mon Jul 24, 2017 6:39 pm
Welcome to TR.
Good resource here.
viewtopic.php?f=11&t=95930
