Post new topic Reply to topic  [ 286 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19, 20  Next
 Post subject: Re: 49cc & PROUD!..............(Specs pg.1) Whats your GUT ICON?
PostPosted: Wed Jan 08, 2014 4:19 pm
ultramagnus wrote:
Shave the drive face before doing any other mods, shaving the DF will help it climb and used slider weights not rollers.
Rad i havent looked into that yet. Thabk you.
Born to be Mild build
jcrabb13 wrote:
IF YOU SAY "about that life" then you ain't really boutdatlife.
PostPosted: Wed Feb 05, 2014 5:16 pm
Edit:
Weight: 170lbs.
Year: 2003
Miles: no speedo
Performance Mods:
Polini Hi Speed Variator
Gates Belt
5.2g Dr. Pulley Sliders
UNI filter with rad hose intake
Opened carb mouth
38/80 Jetting
NCY Cdi
Jiang Wayne Exhaust
Cosmetic Mods:
ATR lowered seat frame
LED strip tail light
PWJDM foot pegs
Origin8 BMX stem
Origin8 MX Mini Urban Handlebars
Tire Specs: (Front 120/70-10) (Rear 120/90-10)
Top Speed: 56mph flats GPS confirmed
Average Cruising Speed: 45mph flats
Elevation: About sea level
Environmental Conditions: Hot and humid miami weather.
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=88520
This is my signature ;)
PostPosted: Wed Feb 05, 2014 7:05 pm
LITE Rider (weigh 150-220lbs*)
Weight:
175 lbs.
Year: 2007
Miles: ~4k? Feb 2014 (xx/xx/xxxx)
Performance Mods:
- Polini Vari w/5.1g Doppler Rollers
- Lightened Flywheel
- RonkSolid Velocity Stack
- Posh CDI
- Custom Windshield
- 2 Brother's Exhaust
Cosmetic Mods:
- 12x8 Fatty w/Viper Stryke (to be replaced with Schwalbe Weatherman)
- 18" Apes
- DORF
- Mojo 10" Fatty Extension
Tire Specs: (Front 120/90-10) (Rear 140/70-12)
Top Speed: ____mph (GPS Confirmed or Stock Speedo)
Average Cruising Speed: ____mph
Elevation: 50ft above sea level
Environmental Conditions: __________
( • • • PLEASE Show Images Last • • • )
Subscribed--Will update.
• DevilRuck
• Big Ruck
® Ruckémon!
 Post subject: 49cc & PROUD!..............(Specs pg.1) Whats your GUT ICON?
PostPosted: Mon Feb 24, 2014 9:27 am
Weight: 194
Year: 2007
Miles: 4300
Performance Mods:
NCY variator
5.5g(shaved) MET rollers
Shaved drive face
Shaved hook off of torque driver and flattened the ramps
Cosmetic Mods:
Lowered seat frame
PWJDM extension
Soma Arc bars w/ Spank mtb stem
Lowered headlights/ turn signals
Modified tail light bracket
Cut down stock forks
Cut coil spring in stock rear shock
Bobbed rear fender
No front fender
Wald kickstand
Tires: stock
Top speed: 54.6
Avg cruising speed: 40ish
Elevation: 4500 ft
viewtopic.php?t=87828
PostPosted: Mon Mar 17, 2014 8:50 pm
Weight: 175lbs.
Year: 2004
Miles: 9k
Performance Mods:
SN Vari 4's n 6's
Gates Kev Belt
35/82 jets
NCY CDI
BR header w/ B&S exhaust
UNI Intake setup
Scooterworks Low Down Shock
Stock Clutch (will soon be adding a yellow contra and blue clutch springs shortly)
NCY Performance Coil
Magnetic Oil drain plug
Cosmetic Mods:
Straight Handlebars (not sure of the make, someone went with another style and donated it to my build)
TruVativ Hussefelt Stem
BR front peg bars
Gas Tank cover
blk side kickstand
NCY lowered seat
taillight lowering bracket
Mojo 12x8 GET fatty stretch kit
Douglas 12x8 w/ Shinko white wall
Shinko whitewall 120/70-10 front, Shinko whitewall 130/70-12 rear
Lbracket side plate mount
Ciroc Coolant tank
Radiator cover
Tire Specs: (Front 120/70-10) (Rear 130/70-12)
Top Speed: 48mph (GPS Confirmed)
Average Cruising Speed: 40-45mph
Elevation: ???? above sea level..... whatever central FL is, I'm not sure
Environmental Conditions: Tropical
PostPosted: Tue Mar 18, 2014 1:05 pm
Heychicoman wrote:
...Shaved hook off of torque driver and flattened the ramps...
:?: What do you mean? Pictures?
Do you have a build thread?
I WOT My Ruckus -ClickMe-.
I WOT to go!
WOW! I have a thread in the feedback section!
PostPosted: Tue Mar 18, 2014 6:03 pm
I read this: https://www.battlescootershopping.com/s ... ioQ2iNReV8
I'm all about the free mods. I don't know if I can tell if it helped much, but it does seem to have less of a slow spot around the mid 30's.
Yes, but it's not that detailed.
PostPosted: Fri Apr 25, 2014 9:07 am
2005 ruckus
all stock
BR Exhaust/Briggs muffler
Air box delete
85 MJ/38SJ
deleted all plastics
lowered sear frame
stock belt
6.0 roller weights
41 cruise
dallas, texas (not sure altitude)
sunny skys! 70 degrees
Sent from my iPhone using Tapatalk 2
High School Budget Build
PostPosted: Mon Jun 23, 2014 6:09 am
Weight: 255 lbs.
Year: 2014
Miles: Took speedo off so I Dunno
Performance Mods:
GET
Yoshi Exhaust
Ronk Stack
35/75 Jetted Stock Carb
Slight Hone to stock intake manifold
Polini Variator w/ 4.5g Sliders & Gates Kevlar Belt
Shaved Driveface
Cosmetic Mods:
Gas tank cover courtesy of ebay
Dorby Works License plate mount
AK 9.5 Skinny Mount
Smoked LED tailight (the one that looks stock wit the integrated turn signals)
Rucking parts lowered stock taillight bracket
Diamond Plate luggage cover
Tire Specs: (Front Stock) (Rear 120/90/10 Bopper)
Top Speed: 50.1 mph (GPS Confirmed & going downhill)
Average Cruising Speed: 40-46 mph Depending on the streets.. a lot of stop and go in my area
Elevation: 67ft above sea level
My Slow Build : viewtopic.php?f=96&t=73920
GET
Yoshi Exhaust
Ronk Stack
38/75 Jetted Stock Carb
Polini Variator w/ 5g Sliders & Gates Kevlar belt
PostPosted: Tue Aug 12, 2014 7:09 pm
155 lbs
08 met
5.5g dr pulley sliders in a SN vari
uni filter on a rad hose
gutted muffler
40/75 jetted, shimmed
tto tach
100/90 rear rubber
top speed 45mph @7920 rpm's
'83 Aero 80
'84 Aero 125
'02 Met Emo
'08 Met Ginger
'09 Met Goth
'06 Elite 80
'87 Elite 150
'89 Elite 250
'03 Met "Emo" GY6 Build
'08 Met "Ginger" 50cc Build
'09 Met "Goth" Build
PostPosted: Sat Aug 16, 2014 8:07 pm
2011 Ruckus
160lb
1,200 miles
Engine mods:
Ronk Stack intake
BR header with B&S muffler
Polini variator with 5 gram rollers
Daytona kevlar belt
38SJ//72mj
NCY CDI
Top Speed: 41mph on the flats (8200 rpm), 50mph down hill(9500 rpm)
Elevation: 1500ft above sea level
Still have some variator tuning to do. It seems to like lighter weights. Acceleration is awesome and pulls hard up to about 40mph.
2011 Ruckus (Black)
Polini variator, Polini Rollers(5.5g), Dayton Belt, Posh clutch springs, NCY CDI, B&S exhaust
Works Connection Tac, Slow jet 38, main jet 72, Ronk Solid Stack
PostPosted: Wed Aug 20, 2014 9:23 pm
Weight: 185
Year: 2013
Miles: 585 8/29/14
Performance Mods:
polini hi speed variator
gates belt
rad hose intake
br exhaust
ncy cdi
38/85
Cosmetic Mods:
mojo fatty 12.5 stretch
mojo handle bar stem
drag bars
chimera seat frame
10x8 rear wheel
hoodrich gas tank cover
r6 tail light
rrg down lows
Tire Specs: (Front ____/__-10) (Rear 140/90-10
Top Speed: 48 flat 55 down a huge hill gps
Average Cruising Speed: 45 gps
Elevation: 345 above sea level
Environmental Conditions: hot 80+ usually
my build- viewtopic.php?f=92&t=87084
PostPosted: Mon Aug 25, 2014 7:34 pm
Weight: 177lbs.
Year: 2011
Miles: 2700 Date (08/25/2914)
Performance Mods:
CR80 ProCircuit slip on
Intake mod
Jets ordered
Cosmetic Mods:
MNNTHBX DORF Seat Frame
R6 LED Taillight
Front LED short stalk blinkers
Custom headlight mount (cut up stocker)
Speedometer, turn signal indicator in BBox
Tach
___________________________
Tire Specs: (Front 130 / 90 -10) (Rear 140 / 90 -10)
Top Speed: 38mph (GPS & Stock Speedo)
Average Cruising Speed: 30mph
Elevation: 784 above sea level
2011 Ruckus 49cc
Build Thread: viewtopic.php?f=92&t=92039
2003 Yamaha Warrior 350
Build Thread: http://www.yfm350.com/forums/showthread ... post354443
PostPosted: Tue Aug 26, 2014 11:52 pm
Weight: 230
Year: 2009
Miles: 5738
Performance Mods:
Daytona Variator
Daytona Kevlar Belt
Daytona Racing CDI
6g roller weights
Foam drop in air filter
Battlescooter Clutch Spring kit
Battlescooter Performance Pulley Spring
Cosmetic Mods:
Shaved and lowered front turn signals
Tire Specs: Stock Kendas
Top Speed: 44 flat, 50 down hill (GPS confirmed)
Average Cruising Speed: 36-38
Elevation: at sea level
Environmental Conditions: mild to hot
PostPosted: Fri Aug 29, 2014 9:41 pm
Weight: 215lbs
Year: 2012
Miles: 8000__ Date 08/25/14
Performance mods:
Home made rad hose intake
Uni filters
Hmf exhaust
Jetted 38sj 78mj
Polini variator
Dr pulley 5g sliders
Oem bando belt
Boppers front and rear
Cosmetic Mods:
Ncy seat frame
Ncy storage tray
Ncy fuel tank cover
Mojo handlebars and mount
Shaved and lowered turn signals
Mnnthbx pegs
Ncy stretch
Zuma rear shock
Mnnthbx pair block off
Pwjdm kick start lever
Cheapo bar ends (blue)
Blue battery box washers
Blue vinyl seat
Tire Specs: (Front 12-90-10) (Rear 130-90-10)
Top Speed: 46 mph flats 52 down hill(GPS Confirmed)
Elevation: 600ft above sea level
Environmental Conditions: 85 and clear
