Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
 Post subject: Noob: Intake Modification
PostPosted: Tue Mar 24, 2009 2:08 pm
I need some help modifying my intake system on my 03 ruckus, I've been going off of Sanjuro62 thread viewtopic.php?f=34&t=10043 for modifying intake systems for the 06-09 ruckus. So I've ripped out my stock air box and I am running the snorkel with a K&N intake filter, I put a breather filter on the left side of the carburetor, and I'm trying to find out if the 03-05 ruckus have the PCV Solenoid Valve. Not being able to find anything that looks like the PCV Solenoid, I am not able to attach the breather filter to it. Has anyone else had this problem? Please help. :oops:
 Post subject: Re: Noob: Intake Modification
PostPosted: Tue Mar 24, 2009 2:12 pm
pre '06 models do not have a pcv.
tuners tune on las tunas eatin tuna fish samiches!
http://kiwi2racing.com/
Patron Saint of TR
Patron Saint of TR
The 03-05 ruckus does not have the PCV setup like the 06+ ruckus. You need to plug the hose that comes from the top of the head or attach a small breather to that also. Then you should be good to go, thats how I had it on my 03. :)
The "Addiction"
SSBC: Under Compensating Daily Since 2008
TT-350z wrote:
thats like me rocking ssbc stickers without meeting stimpy :twisted:
PostPosted: Tue Mar 24, 2009 2:41 pm
you also need to plug the vacuum line that was connected to the pair control valve.
pix o' F&A!
Con07, 08, 09, ReCon08+1, SS10, 11, 12, MHM13, 14, 15, HTR B2Q3, SuperfadedCon10, The High Desert Gathering11,12, ScootNM2012
WAN named me "Uncle Paul".
PostPosted: Tue Mar 24, 2009 5:03 pm
Thanks for your help guys, I appreciate it. I'm gonna take a look and figure it out now. :banger:
PostPosted: Wed Mar 25, 2009 12:16 am
So I now plugged both the line coming from the head and the vacuum line. I know that when you install an intake it messes with the air to fuel ratio and a rejet is required. When I started up the ruck, it will idle for about 2-4 seconds and die. When I give some throttle, it dies as well. This is normal when the carburetor has not been rejet or should it be running but with a lot of hesitation? I just want to make sure that I did the modification before I start rejetting my carb. Thanks again for the tips and advice guys! :D
PostPosted: Wed Mar 25, 2009 4:47 am
There is a how to of how to do it w/o rejetting around here I think.
ComposiMo wrote:
Yea, I've always wanted it to look like I was buttf$*&ing a skeleton
PostPosted: Thu Mar 26, 2009 8:46 am
Try this without re jetting:
viewtopic.php?f=34&t=29365
I am a gentlemen and a scholar!
My Scoot
PostPosted: Tue Apr 14, 2009 1:28 am
please tell me that when u "plugged" ur hoses, u mean that u put breathers on them, cuz if u cut off the air completely to one of the tubes, then ur engine will die a few seconds after u start it.
S.R.R
my ride
viewtopic.php?f=93&t=37384
PostPosted: Tue Apr 14, 2009 10:45 am
wait what holes did you plug??
Patron Saint of TR
Patron Saint of TR
PostPosted: Tue Apr 14, 2009 11:01 am
My original post was kinda misleading, sorry!!! :oops: You want to put a breather or just leave the black hose on the tube that's at the top of the head. Plug the PAR valve which is on the lower left side of the head. Also plug the vacuum line that comes off of the intake manifold. Sorry for the wrong information, I didnt read what I wrote very well!!! :oops:
I'll take a couple of pictures tonite to show you exactly how yours should look!!!
The "Addiction"
PostPosted: Tue Apr 14, 2009 12:22 pm
I plugged the PAR valve, left the hose and the CCV but that vavuum line on the intake manifold are you talking about?? the PCV?? Or the Side Carb??
Patron Saint of TR
Patron Saint of TR
PostPosted: Tue Apr 14, 2009 12:41 pm
If I remember right there is a 1/4" nipple right in front of the carb on the intake manifold.
The "Addiction"
PostPosted: Wed Apr 15, 2009 12:12 pm
is there any step by step (what to plug and what not) intake install for pre-06 ruckus?
2004 "BrownCamo" Ruckus
2007 Metropolitan
2008 Mugen Civic Si
2007 Tundra DC Limited
2007 Suzuki LT-R450
1991 Integra
P-Town Scooter Crew "PTSC"
freshdrive "FDE"
Patron Saint of TR
Patron Saint of TR
PostPosted: Wed Apr 15, 2009 1:12 pm
I forgot I made this awhile ago for the PC20 swap but I think it should be the same, a picture worth a thousand words!!! :)
Note: this diagram is for an 03-05 model ruckus
Hope it helps!!! Someone please let me know if this isn't correct for the stock carb application..... :)
The "Addiction"
Rucksters browsing this forum: MONKEYnuts and 2 guests
