Post new topic Reply to topic  [ 139 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
 Post subject: Re: GEARING DISCUSSION THREAD
PostPosted: Tue Feb 26, 2013 12:51 pm
Strokd_GE wrote:
ConElite wrote:
Takes Head work or BB power to push a full set of MET gears.
Yeah, body weight is the biggest factor when running those gears but they are the secret to unlocking big mph from these engines
I always felt as though the gearing would be too much until I saw and rode some GETs with head work running fantastic with the full set
which one can i switch instead of doing the whole set? i might try that also while I'm in there. is it the long one, the wide one, or the short stubby one :wasted:
i'd imagine the long one
TWSS
BaconLiar wrote:
Front frame can go to hell.
CT70 (daily) | People's Champ | aggielandscoots.com
PostPosted: Tue Feb 26, 2013 12:56 pm
Start with just the final, the one that exits the tranny and the wheel bolts too
The other two are the little nugget one and the ring that goes on it
-Ruckus
-Big Ruckus
-Grom
PostPosted: Tue Feb 26, 2013 1:00 pm
The Nugget gear is called the counter shaft and gear I believe.
08 Metro- 64/58 club :banger:
viewtopic.php?f=92&t=63326
09 Metruck- SOLD
viewtopic.php?f=92&t=79193
ConElite for Mod 2016!!!!
PostPosted: Thu Feb 28, 2013 5:19 pm
Lol im calling it the "nugget" from here on out.
OttoFactory Build Thread
PostPosted: Fri Mar 01, 2013 6:23 pm
nugget gear it is. if the weather holds out, i might take a crack at this on sunday.
PostPosted: Mon Mar 04, 2013 6:46 pm
so i swapped out the met final gear. replace tranny fluid and used the same thrust washers that came with the respective gears, and i was getting a high pitched whine on decel. i think there may be a noise on acceleration as well but it's hard to hear w/ the MNNTHBX exhaust. if it's there, it's definitely not as loud.
top end was about the same but i definitely lost some acceleration. i have a white and blue contra spring on the way but i don't think that's my issue for the time being.
obviously, i was bummed with these results and tried to go back to all ruckus gears today...it's still whining. i roughed up/slotted the clutch pads and the bell, to no avail.
thoughts on what this noise could be? it sounds like it's coming from the clutch or gearbox.
PostPosted: Tue Mar 05, 2013 4:01 am
fuck it, lets go for the triple post.
the only useful thing to come out of my gear endeavors;
hadn't seen anyone say anything about this particular difference, so figure'd i'd show what i found. 05 met on the left, 08 ruck on the right
PostPosted: Tue Mar 05, 2013 5:44 am
^X2. Shame on me for never posting that I discovered the same thing AFTER experiencing problems similar to yours. I think it may have caused excess vibration and an eventual cooked main bearing.
My Met Build
PostPosted: Tue Mar 05, 2013 7:05 am
I have my met final gear and no whine or noise. There is a Noticable play now but not that much.
As for loss in accel, Thats a given being that your going to a taller gear. This can be corrected with more cvt tuning. Should give you about 2-3mph at the same rpm as before.
I found the best combo is supa light weights and heavy contra. And Since I run a polini var its already geared for top end so I found that 4.7g sliders and a 1500rpm contra worked best for me.
Also one thing that helps a ton is a properly shaved Driveface. and by proper I mean the actual face, not the nipple that comes into contact with the boss and a thin belt. Gates worked best for me. I wanna try a daytona eventually. I know that one is thinner than gates.
09 Metruck- SOLD
PostPosted: Tue Mar 05, 2013 11:32 am
looks like i screwed something up in the clutch. found an old rusty one in the box o parts and the noise is gone, but engagement sucks. time to tear apart the old clutch and see what went wrong. :meh:
PostPosted: Tue Mar 05, 2013 11:36 am
Whats it doing? Slips to much on take off.
09 Metruck- SOLD
 Post subject: GEARING DISCUSSION THREAD
PostPosted: Tue Mar 05, 2013 12:14 pm
Ya. Just old. I'm gonna tear apart the one that was yelling and see if I can get that one functional again.
PostPosted: Sun Mar 31, 2013 5:27 am
I had a horrible noise come out of mine when I went full MET, turns out it was just a bearing. Took the set out of my original swingarm and noise disappeared.
PostPosted: Sun Mar 31, 2013 5:53 am
The whine is coming from the bearings in the transmission case. I changed out to full met gears after I heard it, and still had the whine, so I swapped on a fresh case with bearings, and new main bearing, and it went away.
Un-Named: Zuma 125 Build
Gretchen:
PostPosted: Sun Mar 31, 2013 6:03 am
wasnt yours mainly the brake line rubbing the rim? :P ^
MY OLD 40K MILE RUCK
MY JANKY NEW BUILD
