Post new topic Reply to topic  [ 139 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10
 Post subject: Re: GEARING DISCUSSION THREAD
PostPosted: Tue Mar 01, 2016 10:27 am
I may have missed it, but what is the weight difference between the Ruckus and Kymco rear pulley/clutch setup???
2013 66.6cc Fatty GET
PostPosted: Tue Aug 09, 2016 7:38 pm
The Aero NB50 Gearing + 47 ruckus tooth gear ( 34/12 x 47/13 ) was too tall for my 12" fatty set up and was sluggish pushing to 50mph+. So I put the gears in an old Met swing arm. These might work well with the smaller Met rear wheel. Gears fit perfect.
Met Gears 42/12 x 45/12 = 13.125 ratio
Aero/Ruck 34/12 x47/13 = 10.243 ratio
28% increase.
This gear set up could take the 39 mph Met to 50 mph if you can hold RPM. I'd give it a try but I don't want take apart my daughter's METII.
Happypancake! BBB - Shorty Fatty : viewtopic.php?f=93&t=95381
Angry Waffle! 4-Valve : viewtopic.php?f=93&t=107151
You be the next happypancake! Keep it up!
PostPosted: Fri Sep 09, 2016 11:37 am
Happypancake, are you also into/or were into motorized bicycles? Your screen name looks familiar from the motorized bicycles forums.
PostPosted: Fri Sep 09, 2016 2:32 pm
Not me
Rucksters browsing this forum: No rucksters and 5 guests
