Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Spark plug reading
PostPosted: Fri Apr 15, 2011 11:37 pm
goatlover wrote:
Black and White no Good.
Its gotta be Brown so you can be DOWN!
JEDI pass the Cheese, I gots the CRACKA
LOL
PostPosted: Mon May 09, 2011 7:51 pm
Interesting reading.!
"BlueBallz,Darkness,Scrappy,MetRuckus" projects!!
viewtopic.php?f=93&t=54106&p=889149#p889149
PostPosted: Mon May 16, 2011 1:18 am
Varroa is correct, if the clutch is still spinning at above engagement rpm then the motor is still spinning and sucking in fuel. You can test this out for yourself by getting up to speed and turning off the ignition and as long as the clutch is still engage you can turn the ignition back on and the motor will fire right up. I've done this many a times on long (miles) down hill runs.
So how much of the unburnt fuel changes anything if at all...I have no clue. But what I do for a plug test is as soon as I kill the motor I also kill the throttle to minimize fuel intake and stop the bike as quickly as possible to minimize the motor turning over.
PostPosted: Mon May 16, 2011 5:56 am
Yeah, I switch of the kill switch, key switch, and come to a stop as quickly as possible.
I have also noticed that my belt is fully extended. Makes changing variators/weights a snap!!
PostPosted: Sun Jan 15, 2012 6:41 pm
Good idea!! Never tried that trick.
The Sickness
"I never did mind much about the little things"....
PostPosted: Sat Mar 31, 2012 10:11 pm
I'M SO NICE CREW
BUILD THREAD:http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=64905
PostPosted: Mon Jun 18, 2012 12:30 pm
I am needing a jet Jedi. I have been racing and tuning 4 wheelers most my of my adult life and have never run into this problem. I have a new 2012 ruck with a K&N filter with holes drilled in the air box and Yoshi stainless pipe. After reading a bunch of threads on here, I started out with 85/38 jets. the 38 seems to be perfect when riding and checking the plug. At half throttle, my Ruck nose dives and sputters. When I pull the plug, it is white. This should mean that it is very lean. I am now up to a 105 jet and it runs all the way up to about 33 before it starts popping a little. Using the web page to check jets on the first post, I am around pic 22 to 23. I have not seen anyone have this same issue with this large of a jet. I ordered 108, 110, 112, and 115 jets today. Has anyone else run into this problem? Oh yeah, I am at 460 foot above sea level.
Thanks
2012 Ruckus, Yoshi exhaust, K&N filters, waiting on new parts to arrive!
PostPosted: Mon Jun 18, 2012 5:36 pm
Which one boss?
Unless it was soaked with gas i've never gotten good readings off pulling the spark plug on a ruckus. Just my experience. I'd say it's okay to start with a 38 slow jet but go back to the 75 main and go up one size at a time.
You'll be able to recognize your symptoms to your jetting better.
PostPosted: Sun Jun 24, 2012 8:07 pm
thanksss
PostPosted: Fri Jun 29, 2012 1:07 pm
I think I need a little more MJ. This is a 38/80. Might try my 82 MJ.
ruck1built
Quality. Custom. Fabrication.
Z125 Crew
PostPosted: Sun Sep 16, 2012 6:14 am
Getting closer.... Not quite right
Pauls Panda-monium <-- my retired build
MYSD Black nd Plum <-- side project
OC reppin
250 bangin :flip:
PostPosted: Fri Sep 21, 2012 3:56 pm
thanks for the info!
GETtin it done son!
PostPosted: Thu May 16, 2013 12:02 pm
How does this look? Sorry about the picture size I don't know how to make it smaller.
My crap build. viewtopic.php?f=92&t=82780&p=1423489#p1423489
PostPosted: Mon Jul 01, 2013 9:29 pm
Only mod I have is a K&N filer on the stock snorkle. Trying to dial in my jetting. Went one currently have one step larger main jet and pilot jet.
How does this plug look? possibly still lean?
2011 Ruckus (Black)
Polini variator, Polini Rollers(5.5g), Dayton Belt, Posh clutch springs, NCY CDI, B&S exhaust
Works Connection Tac, Slow jet 38, main jet 72, Ronk Solid Stack
 Post subject: Spark plug reading
PostPosted: Sat Jul 13, 2013 1:24 pm
Good information here!
My Build
