Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: KILLER GOODIES
PostPosted: Mon Aug 17, 2009 3:19 pm
All KILLER SCOOTER Products are for OFF-HIGHWAY USE ONLY.
WELCOME TO THE DARKSIDE!
YES I KNOW! This Thread is USELESS with pictures, but you'll have to bear with me...
Please Contact your local KILLER SCOOTER Dealers for inventory for product availability:
BTX Industries (BTXMW@yahoo.com)
Rucksters.com
MakoaScooters.com
GY6
KS GY6 Ruckus Mounts $525 (JUST IN, They are shipping to your Local Dealers NOW)
The Original Engine Swap kit for the Honda Ruckus...The strongest, the straightest, the longest and Most reliable engine swap mount on the market today. The design for this piece was simple...make it Long, Make it Low, but definitely make KILLER!
KS Wiring Harness GY6 - for 6/8 pole Stator $495 (Requires Core harness)
The only Flawless Plug and Plan Wiring Conversion kit available for your Gy6 to Ruckus. Simply connect all your factory controls and lighting system and Vroom! you're up and running with all DOT approved indicators.
KS Wiring Harness GY6 - for 11 Pole Stator (Includes Rectifier and Stator) $545 (Requires Core harness)
This Wiring System allows for use of many heavy load electronic devices. The Charging System charges between 13 and 16 Volts. Also converts your lighting system from A/C to D/C. No more Flickering headlights. Allows the use of HID's and other electronic devices without sacrificing the charge of your battery.
KS 6 Spoke Wheels for Long Case GYSIK (Sold Out as of 1/4/2010)
KS 6 Rear Singles available for $225
These wheels are 12 x 3.5 and a perfect compliment to the Dunlop TT92 or Michelin Pilot Sport Tires. Available in Silver with a Silver Machined Lip. Drum Brakes only. Not Compatible with GY6 Short Cases.
KS KILLER GY6 Performance MOTOR Packages: Special Order: All motors come complete with the Standard CDI, Regulator, Carburetor, and Coil.
KS KILLER TOUCH - $225 Port and Mill your GY6 Head. Send us your Head and we'll make that sucker Breath Right!
KS STREET Package: $875 Complete GY6 150cc Motor with the KILLER TOUCH - Ported and Milled head and assembly of the head.
KS SPORT Package: $1,275 Complete GY6 150cc Motor, 180cc Big Bore Kit, and Assembly.
KS RACE Package: $1,500 Complete GY6 150cc Motor, 180cc Big Bore Kit, and Assembly with the KILLER TOUCH - Ported and Milled head.
KS OUTLAW Package: $1,800 Complete GY6 150cc Motor, 180cc Big Bore Kit, +2mm Stroker Crank, Assembled with the KILLER TOUCH - Ported and Milled head.
$40 off all motor Packages above when Purchased with Either a KS Mount or KS Wiring Harness.
$100 off all Motor Package above when Purchased with the KS Mount & KS Wiring Harness.
GY6 Short Axel Conversions $45
Get the right Axel for your conversion. Spaced appropriately so it doesn't crack your bearings.
GY6 Intake Manifold for Mikuni TM24 $60...Add a Silicone Boot for $20 for TM32 Carbs.
JCR - Throttle Cable $20
2 STROKE Galaxy
KS 2 Stroke Mounts $345
The Original USDM Custom Minarelli Mount. Mounts are pre-welded to your frame with Core exchange. Comes with Shock Extension. For use with Yamaha Zuma's, Vento
KS Wiring Harness Zuma 2 Stroke $495
Another Flawless Plug and Plan Wiring Conversion kit available for your Zuma to Ruckus. Simply connect all your factory controls and lighting system and Vroom! you're up and running with all DOT approved indicators. No need to vaccuum nipple to drill into your engine casing engine casing to create a
KS Floating Oil Tank / Auxilary Gas Tank $195 (1 in Stock, Special Order)
These Floating Tanks are 3" in Diameter, Vented, includes Seat Straps and hardware.
Minarelli Intake Manifolds $60 for Kehein PE20 and Mikuni TM24
Motor Building Services Availalbe
ACCESSORIES
KS Seat Frames $175
Super Low Seat Frame with a Stubby Tail Tucked nicely under your seat. A perfect Compliment to the KS Slim Bright - LED Tail Light System
KS Slim Bright - LED Tail Light System $195 (Out of Stock)
The Original KILLER SCOOTER Super Slim Tail light System. this is a 4 Piece System, Pre-wired Tagged, and Mounted for easy installation.
KS Super MINI's Signal Lights $49 per Pair (Limited Stock)
KS 6 Shooters $69 Available in Black, Gold, Silver, Blue and Red
The perfect compliment to your KILLER bike. buy any other KS Product and receive the 6 Shooters for only $50 with your order.
KS LOGO T's $20
Carburetor Upgrades
Get the Breath of Fresh air for you Scoot with one of these amazing Carbs...
Mikuni TM 24 Carburetors $175
Mikuni TM 28 Carburetors $175 (out of stock)
Mikuni TM 32 Carburetors $175
Mikuni Jet Kit 1, Includes 3 Slow Jets and 4 Main Jets $29 Out of Stock
Mikuni Jet Kit 2, Includes 3 Slow Jets and 4 Main Jets $29 Out of Stock
Stage 6 PWK 24 Carburetors $165
Stage 6 PWK 26 Carburetors $165 Out of Stock
Stage 6 PWK 28 Carburetors $165
PWK Jet Kit 1, Includes 3 Slow Jets and 4 Main Jets $29 Out of Stock
PWK Jet Kit 2, Includes 3 Slow Jets and 4 Main Jets $29 Out of Stock
Kehein PE20 Carburetors $120
Kehein PE20 Jet Kit Includes 3 Slow Jets and 4 Main Jets $29
COMING SOON:
KS InvisiThrottle kit (COMING SOON)
KS Zuma125 Foot Bar with PEGS (NOW AVAILABLE) $139.
KS Zuma125 Stretch Kit (COMING SOON!)
KS GY6 Metropolitan Mounts (COMING SOON!)
KS Ruckus Rear Foot Brake (COMING SOON)
Killer Scooter welcomes you to the DARKSIDE!
キラー スクーター
Subliminal message of the Year: 2011 Ingenuity is the new Duplication
KILLER GOODIES
KILLER KRAFTED MACHINES
OG KILLER K125
 Post subject: Re: KILLER GOODIES
PostPosted: Mon Aug 17, 2009 3:29 pm
Killer Scooter at it again.
PostPosted: Mon Aug 17, 2009 8:00 pm
bump this man and his awesome parts topped with awesome sauce :banger:
PostPosted: Mon Aug 17, 2009 10:17 pm
Xie xie SIFAT! :wasted:
ALOHA!
ALOHA! :wavehello
MAKOA SCOOTERS
PostPosted: Mon Aug 17, 2009 10:26 pm
HELL YAH KILLERsCOOTER GOOD :banger:
SPREAD THE ALOHA!! no need be hawaiian for ALOHA stop the drama stop the hate.
PostPosted: Wed Aug 19, 2009 10:27 am
shits man too many goodies, I gotta start charging more for slangin them white paint chips.
RRidas:
35 cent (Bumble Bee)
Boogie (Tickler) <----- Rest in peace
Riskek (White Monsta)
Riskek's girl (Black kitty)
"them foos dropping like flies".... by Riskek
2009 & 2010 back2back World champs LA Lakers
The Official Unofficial TR Sheriff!!
PostPosted: Wed Aug 19, 2009 11:04 am
nice!
My Ruckus: http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=54160
- B.I.T.R.
The Bureau of Internal TRama
ruckus2009 wrote:
If he was some troll, I'd be with you- give him the boot. .
PostPosted: Sun Aug 23, 2009 9:08 am
foot brake sounds sick cant wait, we need some pics of these items too !
:banger: for new products
-Mark-
MyMisterWannaB
MyMisterWannaB
Bathroom mechanic
PostPosted: Sun Aug 23, 2009 9:06 pm
got any Mikuni slow jets? (out of stock of the kits so??)
i got plenty of mains, but slows are where its at :banger:
~ RipVanWinkle ~
MAKIN_A_RUCKUS wrote:
It's not the scooter's fault that you're a pussy.
Jedi wrote:
Lots of good clamming and we grow our own milk.
PostPosted: Mon Aug 24, 2009 7:14 pm
how about anyone post pic of the KS low seat with the KS slim light setup
I'm scratchin my head trying to figure which way to go back there
PostPosted: Mon Aug 24, 2009 8:38 pm
I have some slow jets...
do you know what size you need? they are $4.95 a piece... $0.65 shipping.
let me know.
キラー スクーター
KILLER GOODIES
OG KILLER K125
MyMisterWannaB
MyMisterWannaB
Bathroom mechanic
PostPosted: Mon Aug 24, 2009 8:41 pm
will do after i get 'er going! :banger:
~ RipVanWinkle ~
PostPosted: Mon Aug 24, 2009 8:44 pm
キラー スクーター
KILLER GOODIES
OG KILLER K125
PostPosted: Wed Aug 26, 2009 8:16 pm
I would really like to see some more detailed pics of this mount, there not on any site (that ive seen atleast) this mount has been getting good reviews and has always been something ive been considering when i take my bike to the next level shortly. Is it aluminum, steel, ect? p-coated, annodized) any other modifications necessary to install?
-Mark-
PostPosted: Wed Sep 23, 2009 6:27 am
FAHQ :banger:
TTT
