Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Questions and Answers regarding Carbs, Engines, Performance
PostPosted: Thu May 24, 2012 12:32 pm
Mr Stiffy wrote:
What's the recommended valve clearance for the JC racing camshaft?
Use the stock specs
JC Racing
http://www.jcracingonline.com
My Ride
PostPosted: Thu May 24, 2012 8:43 pm
Hey, for the p(j)c20 carb, is it better for me to mount the filter directly to the carb or use the hose?
PostPosted: Fri May 25, 2012 3:53 pm
Its really up to you. You will just have to tune it for whichever way you decide to run it.
JC Racing
My Ride
PostPosted: Mon Sep 17, 2012 6:37 pm
question i heard in a thread that there is an aftermarket valvespring for the GET? if so please pointg me in the right direction. im buildimg a head, port and polish, hollow jc cam and i want to upgrade the valves but i havent seen any options. please tell me theres a light at the end of the tunnel
Project CreamSickle!! MOJO weld on GET stretch and center mount!!!!!!!
viewtopic.php?f=95&t=71039
PostPosted: Mon Sep 17, 2012 6:45 pm
GY6 150 inner valve springs fit but honestly don't bother, the amount of power you're going to sacrifice to open those stiff springs won't help any, factory heads rev up to 10.5 with no problem, you shouldn't need to rev more than that anyway
-Ruckus
-Big Ruckus
-Grom
PostPosted: Sat Oct 27, 2012 6:34 pm
EDIT. meant to be a PM.
"Mr. Rice" :http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=60615
" SYZ " :http://totalruckus.com/phpBB3/viewtopic.php?f=44&t=82858&p=1424656#p1424656
PostPosted: Tue Oct 30, 2012 10:57 am
This....I would honestly just buy a set of brand new valve springs and be done with it. That way you are sure that the original ones havent weakened any and are at full strength.
JC Racing
My Ride
PostPosted: Mon Feb 04, 2013 6:33 pm
I would like to build an intake tuned to operating rpm for me! Could you tell me how long the intake port length is from valve seat to flange (on the head only)?
Da Build
http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=23361&p=321625#p321625
PostPosted: Tue Feb 12, 2013 4:50 pm
What are you doing to "modify" the valves?
You did WHAT?! With WHO?! For HOW MANY COOKIES?!
My ruck viewtopic.php?f=93&t=50889
PostPosted: Tue Feb 25, 2014 7:47 pm
If i send my head to you for p&p do you do more than just port the intake and exhaust ports? And do you put new valves and springs or can i send those to you with the head?
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=88520
This is my signature ;)
PostPosted: Wed Feb 26, 2014 8:41 am
The entire intake and exhaust port is done, not just the ends that are easily seen. I can also install the new springs and valves if you send them with your head, or I can get them, either way.
Hopefully this answers you question.
JC Racing
My Ride
PostPosted: Wed Feb 26, 2014 11:09 am
I picked up a hollowed GET cam from you a little while ago. I'm going to have it installed in a little bit.
Where's the best place to buy new GET valve springs?
something something DAARKSIDE. something something COMPLETE
http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=70621
* * * CHICAGO SPEED CAMERA -MAP * * *
http://abclocal.go.com/wls/feature?section=news/local&id=9203444
PostPosted: Wed Feb 26, 2014 12:23 pm
Partzilla.com
Another question. Ive seen in the p&p thread people do valve jobs and they grind a little of the area where the valves sit i guess to get more combustion? Do you do that?
PostPosted: Wed Feb 26, 2014 10:02 pm
I can deck the head for increased compression. As far as the valves go they are lapped to make sure they get a good seal before reshimming. The rest of what I do is my standard port job.
JC Racing
My Ride
PostPosted: Thu Feb 27, 2014 4:22 pm
Awesome, thanx!
