Guidelines:
 Post subject: DRC Edge II Tail Light with Arrow Blinkers...
PostPosted: Sat Nov 21, 2015 5:12 pm
This is a DRC LED Edge II tail light and LED arrow blinkers made for a Suzuki DRZ Supermoto 400 that I adapted to my Ruckus because I like them so much on my 400. Been running them for seven years to date and they perform flawlessly. As far as I know, no one else has had the idea to put this on a Ruckus as it's not designed for it. However, with a generously large mounting plate it was very easy to adapt. It's really bright and the blinkers are unambigious because they're separate from the tail light.
Instead of removing the stock light mounting "tail" completely, I cut it short and put slots into it so I could bend it horizontal and simply bolted the whole LED assembly onto it. I like how it includes license plate mounting and lighting in the assembly. It's $110 shipped, from WheelingCycleSupply.com, and in my opinion it's well worth the money. The quality and finish are top notch. :)
tooter's scooter mods: viewtopic.php?f=95&t=96795
 Post subject: Re: DRC Edge II Tail Light with Arrow Blinkers...
PostPosted: Sat Nov 21, 2015 8:38 pm
Looks real nice. I used a stock grom led taillight on my ruckus. Much better then stock. And was only 35 shipped on ebay.
TT-350z wrote:
Build Thread
PostPosted: Sat Nov 21, 2015 9:22 pm
:highfive: i like it a lot
PostPosted: Sat Nov 21, 2015 9:52 pm
The Grom LED lights are nice, but I went with blinkers that are completely separate from the tail light as they're more clear, and just one assembly also takes care of the license plate mounting and illumination.
PostPosted: Sun Nov 22, 2015 12:17 am
tooter wrote:
The Grom LED lights are nice, but I went with blinkers that are completely separate from the tail light as they're more clear, and just one assembly also takes care of the license plate mounting and illumination.[/quote
Gotcha. One thing tho, the stock from brake light doesn't have turns so you have to run signals like you did. There are grom replacement taillights that have intergraded turns but not the stock one. ]
Build Thread
PostPosted: Sun Nov 22, 2015 12:43 am
Ah... thanks. I must have been looking at aftermarket Grom lights and didn't realize they weren't stock.
PostPosted: Tue Dec 01, 2015 5:15 pm
Wow, I like that look a lot. Thanks for the post.
Red rOOckus
gy6 super stretch
gy6 off-roader project
Yamaha C3
PostPosted: Tue Dec 01, 2015 10:40 pm
You're welcome, Joel. :)
Because the RuckRack overhangs the rear, it didn't matter that the light was also behind the bar rather than tucked underneath it. The location of the license plate also acts as a mudguard because the rear fender is cut short. The welded on piece that everyone usually cuts off is perfect for the tail light because it comes attached to a large flat metal mounting plate. I just drilled a couple of holes in the mounting plate to match the existing threaded holes in the welded piece and bolted it right on. The Edge taillight is a sportbike setup so it makes the back of the Ruckus look more like a legitimate bike.
I also really like the Ruckrack because unlike other larger heavier more complicated racks, it simply attaches to the 2 existing rear seat bolts and has a center metal tube with a curved end that rests directly on the rear bar. It doesn't interfere with the extra low seat mount and is exactly the same height as the seat so it looks like it belongs there.
PostPosted: Tue Dec 01, 2015 11:21 pm
Me too
fuck.
PostPosted: Wed Dec 02, 2015 5:18 pm
The rear arrows turned out so well, I added matching fronts...
PostPosted: Wed Dec 02, 2015 5:21 pm
Nice, now go tuck that horn into the box.
fuck.
PostPosted: Mon Aug 22, 2016 8:19 pm
hello, was wondering if you remember how it mounts to the bracket? how far apart are the bolts? was thinking about using http://www.ebay.com/itm/Gloss-White-Honda-Ruckus-Tail-Light-and-Turn-Signal-Relocation-Bracket-/262583773923?hash=item3d23366ae3:m:mz6_SHMQrxZX0yzIKQIsIGA&vxp=mtr
with the DRC hoping the holes line up.
PostPosted: Tue Aug 23, 2016 10:10 am
hello, was wondering if you remember how it mounts to the bracket? how far apart are the bolts? was thinking about using http://www.ebay.com/itm/Gloss-White-Hon ... GA&vxp=mtr
I've got one of those brackets and can tell you how far the holes are apart if you need that info. Hopefully the OP can tell you how far apart the bolts are.
Red rOOckus
gy6 super stretch
Yamaha C3
PostPosted: Tue Aug 23, 2016 10:33 pm
i have one as well, just want to see if i can make it work. Hoping Tooter knows the distance between the bolts on the DRC Edge II
PostPosted: Mon Aug 29, 2016 4:06 pm
according to this site: http://www.xt660.com/showthread.php?t=11550
The distance between the 2 bolts is 80-81mm approx centre to centre on the bolts.
Would be good to get confirmation from tooter. Interested in doing this same mod...
Red rOOckus
gy6 super stretch
Yamaha C3
