TotalRuckus Forum Index
Project Raucous - NPS450t - Updated 11/17!!! ;)
Goto page Previous  1, 2, 3 ... 28, 29, 30 ... 60, 61, 62  Next
   TotalRuckus Forum Index -> Members' Rides
View previous topic :: View next topic
bowery4
2002 Honda Ruckus/Zoomer
PostPosted: Sat May 31, 2008 4:43 pm    Post subject:
PomeRuck wrote:
johnny boy! great work on the front hub!!! now you MUST get rid of those stock front shocks... needless to say... they don't go with the rest of your scheme!
X2 might not really be that safe either, think they might bottom out kinda easy, mine do anyway. Think that is why everyone upgrades (somewhere on here or RC there is a how to on a stock upgrade if you just like the look).
Looks great, nice BB and fender. Glad to see you back at it Cool
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=402291491
http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewAlbums&friendID=402291491
http://s69.photobucket.com/albums/i55/bowery4/
Back to top
ComposiMo
PostPosted: Sat May 31, 2008 6:14 pm    Post subject:
Pome: Thanks! Got any good creative suggestions, besides the same old overused Dio front fork that everyone seems to use? These won't be stock for very long anyway. Theres nothing wrong with working with what you have to make it better... its not just about going out and buying parts... anyone can do that Wink
bowery: i won't leave them stock if i do use them... Cool But we'll see... depends on what i can find out there.
John.W
Back to top
rollinjunk
2004 Honda Ruckus/Zoomer
PostPosted: Sun Jun 01, 2008 8:27 am    Post subject:
Cough air----ride cough
Free WIlly
www.bapetalk2.com
OPZ shit -B
Back to top
PomeRuck
2007 Honda Other...
PostPosted: Mon Jun 02, 2008 11:56 am    Post subject:
with that front hub i thought you should have done the single sided swing arm style thingy... with airide X2 Very Happy
www.pomeroymusic.com
www.myspace.com/pomeroybass
Back to top
jc250r31
2006 Honda Ruckus/Zoomer
PostPosted: Mon Jun 02, 2008 12:27 pm    Post subject:
Then he could have used the pretty cap that came with that Hardcore hub.
...yeah I know what hub that is Wink
Lightened Flywheels
JC20 Carb Kits
Back to top
rattmobbins
Like a Lefty??? That would be SO sick!!! DO IT Compo!!!
like so...
I freakin' LOVE the Lefty on my bike. So unique, and works like a charm!
iheardarukus wrote:
Should have had Compo whittle you some out of the titanium from a Lamborghini's brake pads or some shit...
Back to top
ruck_off
2008 Honda Ruckus/Zoomer
PostPosted: Mon Jun 02, 2008 12:28 pm    Post subject:
like so...
LOL, sorry, but that bike looks gimpy. Laughing
2008 Black Ruckus
Back to top
ComposiMo
PostPosted: Mon Jun 02, 2008 1:16 pm    Post subject:
Ya, i'm not doing that right now... lol! Maybe on another one.
jc... i've made no secret of which hub it is, i even mentioned the brand when i first showed a picture of it Wink
John.W
Back to top
ComposiMo
PostPosted: Mon Jun 02, 2008 1:51 pm    Post subject:
Well today i got to work on the right side swingarm axle carrier... I didn't get as far along as i would have hoped though, since i had to run to Cocoa this afternoon to pick up material for another project, but i got a decent bit done Smile
So, first things first... here is what i had going on... i have this plate, and this is where i want the adjustable axle block to sit. So, i need to add support so that it'll be able to withstand the torque this motor will make, and make it permanant.
So, i needed to build a support. After some careful measurements, i grabbed some of my favorite rectangle tubing, and went to work creating the angles and bends that i wanted in the tubing. This is the piece i wound up with:
But first, i had to cut a notch in it, where it bends in... So first, i cut the flat area...
And then test-fit it...
Then, i cut the notch for the 3/16" rear motor mount, so that this rectangle would sit flat against the backing plate...
Then once i had that done, i measured, and cut a notch where the axle carrier would sit, and cut that on the band saw. Once i had that all done, here is how it all fit together...
Once that was sitting pretty, i had to finish the slot that the axle will ride in for the adjustment. So, i pulled out the trusty jigsaw, and cut the rest of the slot in both the axle block, and the flat backing plate...
Once that slot was cut, i fixtured everything together for one last tack weld and measurement session to make sure everything would fit right and lined up right...
And once i was happy, and everything was level and straight, i welded most of it up!
And there you have it! Now i just need to weld in the adjuster nut, which i already drilled the hole for, then box in the adjuster bloc, and finish welding the support to the backing plate, and then i need to make the backside support, which will run between the vertical upright, and the lower swingarm to provide added side-to-side strength for the arm. Also, i can box in the lower section of the trailing arm where the 'crescent' shape is, and of course the open end of the rectangle box section there at the bottom of the rear motor mount.
John.W
Back to top
jc250r31
PostPosted: Mon Jun 02, 2008 3:05 pm    Post subject:
Oh, I didn't know you had posted a pic of it before those. I wasn't saying you were trying to keep them secretive or anything. Being involved with ATV Motocross I just knew what they were anyway.
You should machine the center cap to where the axle fits through it and bolt it up. I think it would look killer plus keep the bearing enclosed some.
Lightened Flywheels
JC20 Carb Kits
Back to top
ComposiMo
PostPosted: Mon Jun 02, 2008 3:13 pm    Post subject:
No need to... i have a trim ring being machined right now that'll look better than that cap.
As for the Hardkor cap, it is useless with this setup even if i wanted to use it, since it fits into the exact space being occupied right now by the new bearing carrier. Also, my bearing carriers are designed to accept the OEM Honda axle seals, so dust won't be an issue anyway Wink
John.W
Back to top
jc250r31
PostPosted: Mon Jun 02, 2008 3:16 pm    Post subject:
Even better. Twisted Evil
Lightened Flywheels
JC20 Carb Kits
Back to top
D Garage
PostPosted: Mon Jun 02, 2008 4:01 pm    Post subject:
This thread is SICK!!!!! For one you have inspired me to buy a ruckus.... and two you have inspired me to step up my FAB game and buy a tig welder. My mig welds can't come close to those welds right now.
Back to top
Colin
PostPosted: Mon Jun 02, 2008 4:14 pm    Post subject:
D Garage:
Looks awesome, ComposiMo. Can't wait to see the finished product. Smile
Colin Doyle
1985 Merkur XR4Ti | 1990 Subaru Sambar | 2008 Honda Ruckus
Back to top
ComposiMo
PostPosted: Mon Jun 02, 2008 6:07 pm    Post subject:
jc: indeed it is Cool
D Garage: Sweet! Welcome to TR! I'm glad i was able to assist in a small way to you making the decision to go for the Ruckus! Smile Its a great platform, and a lot of fun to modify! i can't wait to see what you wind up doing with yours! Good luck with that TIG Wink
Colin: Thanks! You and me both!
John.W
Back to top
Display posts from previous:
Page 29 of 62
© TotalRuckus.com 2009 - All Rights Reserved --- Powered by phpBB © phpBB Group
