| View previous topic :: View next topic |
| Author |
Message |
pedi-oto Junior Mint
Joined: 09 Jul 2006 Posts: 85 Location: Winston-Salem, NC
Posted: Sun Jan 27, 2008 11:25 am Post subject: custom leg shields...check this out!!! |
I just got these mounted and I was very excited about how it turned out...so I wanted to get some pics posted to get some feedback. I still need to do some tweaking...need to shape some of the edges, I need to take down a little of the plastic around the front fender so it doesn't rub when turning, and I also plan to slide these medially and interlace some of the plastic with the headlight mount for further stability.
I got a used Memphis Shades Hellcat windshield pretty cheap on e-bay. I split it vertically using a dremel tool (easy!), exchanged sides and inverted, and mounted it to the 7/8" bar above the foot platforms. (I had to loosen the parking brake housing on the right side) One thing I like about Memphis Shades is that the mounting hardware is super beefy. They are VERY stable as is. I haven't had the bike up to speed yet, however I doubt that I will need a second mounting point. (I'll let you know how that goes)
I know this won't be nearly as effective at keeping air off me when riding in the cold weather compared to the OEM legshields. However, these were much cheaper, much more aerodynamic, and look a helluva lot better (I think)!!!
| Back to top |
Sawman Dirty Sanchez
Joined: 02 Oct 2006 Posts: 2295 Location: Trenton, Ontario, Canada!
2005 Honda Big Ruckus
Posted: Sun Jan 27, 2008 12:17 pm Post subject: |
dude!.....they're sweet!,.....but can i make one suggestion to you??
......mount that windshield to your handlebars!,...then move those leg shield mounts back 3 inches & down 3 inches, to the tube frame between the footrest & the 2" frame,....would look SO much sweeter & cleaner.....& probably actually deflect the wind better, less wind felt, due to them being closer to you. You might have to reverse those legshiled mounts,....and have the bottom of them about ankle height....
as well,...you could use TWO mounts on the same frame in that location, to give a much sturdier mount. _________________ Ride'er like ya stole'er! |
| Back to top |
BrotherRoscoe Shot Caller
Joined: 22 Sep 2007 Posts: 1553 Location: Statesboro, Ga.
2006 Honda Big Ruckus
Posted: Sun Jan 27, 2008 1:15 pm Post subject: |
They do look pretty sweet dude. Seriously, let us know how the big test ride goes. _________________ 2006 Big Ruckus
CarolinaCon 2009
"Son you gotta panty on yer head." |
| Back to top |
Lagerhead Junior Mint
Joined: 16 Jun 2007 Posts: 51 Location: Cincinnati Ohio
Posted: Sun Jan 27, 2008 2:15 pm Post subject: |
Very nice. Looks like riot gear.  _________________ The best things in life are not things. |
| Back to top |
katmandoitall Space Docker
Joined: 28 Oct 2005 Posts: 3355 Location: Pittsburgh, PA 15203 Allegheny County
Posted: Sun Jan 27, 2008 2:28 pm Post subject: |
I like the approach; would like to see a bit of tweaking.
Would be nice if they could be swiveled at will with a locking
hand wheel once in the desired pattern. In warmer weather I'd
like to scoop in some cool air and close them down a bit in
cooler weather.
I was thinking of placing operable vents like those of old Vetter
windshields into my OEM legsheilds. Would also like to cut a port
in the right one for my HELLA Micro HID lamp to shine through. _________________ "A tyrant must put on the appearance of uncommon devotion to religion.
Subjects are less apprehensive of illegal treatment from a ruler whom they
consider god-fearing and pious." Aristotle
Buy something: http://www.cafepress.com/TotalRuckus |
| Back to top |
Todd One of Us
Joined: 06 Apr 2007 Posts: 745 Location: Louisville, KY
Posted: Sun Jan 27, 2008 2:40 pm Post subject: |
Very clever!  _________________ I would change my avatar but Sawman and BIGWIZ won't let me! |
| Back to top |
Posted: Sun Jan 27, 2008 3:37 pm Post subject: |
| Sawman wrote: |
as well,...you could use TWO mounts on the same frame in that location, to give a much sturdier mount. |
The FRONT PIPE SET is 1-1/2" not 2". The ATV light mounts from PIAA
would be good to make a support with some sort of bent rod with
threads in the ends like the OEM windshield mounts from Japan. I think
they are 6mm thread with rubber grommet in windshield and
a washer under the bolt that goes through the grommet. OEM
has a phillips screw with a mushroom head on it. _________________ "A tyrant must put on the appearance of uncommon devotion to religion.
| Back to top |
HiTechRedneck Donkey Puncher
Joined: 28 Sep 2005 Posts: 5095 Location: Owens-blow, MO
Posted: Sun Jan 27, 2008 5:39 pm Post subject: Re: custom leg shields...check this out!!! |
"It' Optimus Prime, bitches!"
| pedi-oto wrote: |
Nice! And really, makes it look Total Transformer  _________________
| Vladimir Nabokov wrote: |
Complacency is a state of mind that exists only in retrospective: it has to be shattered before being ascertained.
| Back to top |
BRed Shot Caller
Joined: 31 Aug 2006 Posts: 1662 Location: Bethany, NC
Posted: Sun Jan 27, 2008 5:50 pm Post subject: |
Very nicely done..... The windshield I hacked apart to make mine was shorter and created too much wind at my ankles, but yours gives coverage all the way to foot similar to the Battlescooter version.
With the right bag on the front rack, I bet it is very aerodynamic and probably fairly airtight.
( or even an adjustable spoiler? ) ....
I like the whole effect. A nice cold weather setup!
ed _________________ BioHazard
“The country is groaning and moaning and screaming for change.”
Bill Clinton |
| Back to top |
Posted: Sun Jan 27, 2008 6:44 pm Post subject: |
I hadn't thought about putting a bag up front to make things a bit more air tight....nice idea. I plan to move the shields toward the middle more than in the photo...that will help with wind protection also.
I like all the suggestions. Unfortunately, I think the shields are mounted on the only bar that will work since I am using the Memphis Shades hardware and they will not work on larger tubes. I also am wary about making any blemishes on the paint or cutting into anything plastic in the course of mounting the shields. I plan on taking these off in the summer and I don't want to hurt the look of the bike.
I'll post more pics when I have everything finalized and will give a review on how effective these shields are at blocking the wind.
Sawman....thanks for the great recs! I just can't bring myself to mount to the handlebars....I'm concerned about stability (unfounded, I'm sure) and I don't want the windshield any lower than it is right now (I am already using the extended mounting rods) |
| Back to top |
Red Ape 55 One of Us
Joined: 18 Nov 2007 Posts: 578 Location: The IL Side Of St. Louis
Posted: Sun Jan 27, 2008 7:00 pm Post subject: |
That's awesome dude, Ruck On!
Can't wait for pic's of the finished product.
You guys are a wealth of inspiration. _________________
'03 Ruckus - Snapshot
'06 Big Ruckus - Evil Monkey |
| Back to top |
Ali Needs Training Wheels
Posted: Mon Jan 28, 2008 7:49 am Post subject: Wow!! |
Those are way cool!! I can totally see your concept since I mounted my pegs on that frame pipe and you are using the Memphis Shades with the extended mounting rods!! Super nice Bro.....Ali _________________ 2005 Big Yellow |
| Back to top |
art.in.memphis Needs Training Wheels
Posted: Sun Sep 28, 2008 8:20 am Post subject: |
I like them better since you swapped them around and mounted your wind screen to the handle bars. Nice work!
Cheers, _________________ - - Beer, Are You There? It's Me, Arthur. |
| Back to top |
